[mapserver-users] Changing tolerance and toleranceunits at the same
time.
Rui Gomes
ruijgomes at gmail.com
Fri Nov 7 21:42:43 EST 2008
Hi...
I know how to change the tolerance of a layer using a form:
<input... name="map.layer[layer_name]" value="TOLERANCE units"...>
but, if i do at the same time:
<input... name="map.layer[layer_name]" value="TOLERANCEUNITS meters"...>
it will not work. 2 inputs have the same name.
There is some way to change both things?
Thanks.
Rui Gomes
