[mapserver-users] Adding symbols on top of polyline elements
    Adrian Popa
    adrian_gh.popa at romtelecom.ro
    Mon Nov 10 05:48:25 PST 2008
Thank you for your help, Thomas.
Unfortunately, the data is ordered, but it wasn't input in a meaningful
way for what I need, so I can't rewrite it, nor add a flag to it... I
will do some comparisons at the server side, before dynamically creating
the map file and I hope I can pull it off...
Thanks again.
thomas bonfort wrote:
>> By ordered data you mean the direction in this case is A->B?
> yes
>> If I wanted to reverse the direction I'd have to write the data to the
>> shapefile in the order B->A?
> or add a field in your shapefile for that feature, eg reverse=true.
> you'd then have mapserver draw the < symbol for features where
> reverse=true.
> thomas
Adrian Popa
Network Engineer
Romtelecom S.A.
Divizia Centrul National de Operare Retea
Departament Transport IP & Metro
Compartiment IP Core
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081110/a7dbeae3/attachment.htm>
More information about the MapServer-users
