[Mapserver-Users] Problem TEMPLATE to use getfeatureinfo.html
Richard Lehaut
richard.lehaut at crpf.fr
Mon Nov 17 12:12:54 EST 2008
Hello
I try to use the example provided by getfeatureinfo.html Mapfish.org
I joined the mail 3 files:
map.js configuration layers with getfeaturesinfo http://www.nomorepasting.com/getpaste.php?pasteid=21979
websig_norm.map: server configuration wms
I have an error in execution:
Content-type: application / vnd.ogc.se_xml
<? xml version ='1 .0 'encoding = "ISO-8859-1" standalone = "no"? "
<! DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport Version="1.1.1">
<ServiceException>
msReturnPage (): Unable to access file. ttt.html
</ ServiceException>
</ ServiceExceptionReport>
The application n'accès not file ttt.html. I do not know how to configure this file? Is it necessary for getfeatureinfo? What should be the URL?
Thank you for your help
Tio
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081117/d1854c82/WEBSIG_NORM.obj
