[mapserver-users] ms4w (fastcgi) and oracle 10?
zach cruise
zachc1980 at gmail.com
Wed Nov 19 14:11:02 EST 2008
thanks. if i use (DATA "GEOM from STATES using none") from
http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto ("Using
this keyword triggers Mapserver to don't use any geometry function or
spatial operator"), i get white image and changing map extent doesn't
help. if i call it via cgi/webserver, i get http 500 internal server
error.
shp2img -m oracle.map -o oracle.png -e -170 80 -30 -10 -all_debug 10
msOracleSpatialLayerOpen called with: GEOM from STATES using none
msOracleSpatialLayerOpen. Shared connection not available. Creating one.
msConnPoolRegister(layername,username/password at databasename,019A68E8)
msOracleSpatialLayerFreeItemInfo was called.
msOracleSpatialLayerWhichShapes was called.
msOracleSpatialLayerWhichShapes. Using this Sql to retrieve the data:
SELECT rownum, GEOM FROM STATES
msOracleSpatialLayerClose was called. Layer connection:
msOracleSpatialLayerClose. Cleaning layername handlers.
msOracleSpatialLayerClose. Cleaning Oracle handlers.
msConnPoolRelease(layername,username/password at databasename,019A68E8)
username/password at databasname
msConnPoolClose(username/password at databasename,019A68E8)
On Wed, Nov 19, 2008 at 3:03 AM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> Sorry, I cannot help you much further. I checked, however, the SQL against our Oracle 10g Spatial, and I got the same error 'SDO_GEOM' is not a procedure or is undefined. Reason is a typo in SDO_FILTER parameters. Now it reads
> WHERE SDO_FILTER( GEOM, MDSYS.SDO_GEOM(2003
> It should read
> WHERE SDO_FILTER( GEOM, MDSYS.SDO_GEOMETRY(2003
> If it is not just copy and paste error then it looks like MapServer is generating bad SQL
> -Jukka Rahkonen-
>> -----Alkuperäinen viesti-----
>> Lähettäjä: zach cruise [mailto:zachc1980 at gmail.com]
>> Lähetetty: 18. marraskuuta 2008 21:21
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Kopio: Rahkonen Jukka; Richard Polk; Smith,Michael
>> ERDC-CRREL-NH; Jeff McKenna
>> Aihe: Re: [mapserver-users] ms4w (fastcgi) and oracle 10?
>> sql*plus returns this error:
>> ORA-06553: PLS-221: 'SDO_GEOM' is not a procedure or is
>> undefined 06553. 00000 - "PLS-%s: %s"
>> *Cause:
>> *Action:
>> Error at Line:x Column:x
>> "select ID, GEOM from STATES" works though. i have oracle
>> locator not spatial, if that matters. also column GEOM is
>> type SDO_GEOMETRY with MDSYS.SPATIAL_INDEX.
>> On Tue, Nov 18, 2008 at 12:49 PM, Rahkonen Jukka
>> > Hi,
>> > Have you checked that the SQL statement SELECT ID, GEOM FROM STATES
>> > WHERE SDO_FILTER( GEOM, MDSYS.SDO_GEOM(2003, 90112,
>> > NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO
>> > _ORDINATE_ARRAY(-179,-89.5166667,179,83.5166667)
>> ),'querytype=window')
>> > = 'TRUE'
>> > works from SQL*Plus or something else that you are using
>> with your Oracle? If not, then investigate and adjust the
>> DATA string accordingly.
>> > -Jukka Rahkonen-
>> > Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: zach
>> > cruise
>> > Lähetetty: ti 18.11.2008 19:44
>> > Kopio: Richard Polk; Smith,Michael ERDC-CRREL-NH
>> > thanks mike, but i get the same ora-xxxxx errors when using either:
>> > shp2img -m oracle.map -o oracle.png -all_debug 10
>> using unique ID
>> > srid 90112 msOracleSpatialLayerOpen. Shared connection not
>> available.
>> > Creating one.
>> the data:
>> > SELECT ID, GEOM FROM STATES WHERE SDO_FILTER( GEOM,
>> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-179
>> > ),'querytype=window') = 'TRUE'
>> > msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error:
>> > ORA-29900: operator binding does not exist
>> > ORA-06540: PL/SQL: compilation error
>> > ORA-06553: PLS-907: cannot load library unit MDSYS.SDO_3GL
>> (referenced
>> > by MDSYS.SDO_FILTER) . Query statement: SELECT ID, GEOM
>> FROM STATES
>> > = 'TRUE' . Check your data statement.
>> > using 4.8 with /ignored-libmap/oracle10g/libmap.dll. how do
>> i tell if
>> > i have native or ogr support for oracle 10g? i also edited
>> httpd.conf
>> > (did i need to?) from
>> > http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto, but
>> > still no luck.
>> > On Tue, Nov 18, 2008 at 6:42 AM, Smith, Michael ERDC-CRREL-NH
>> > <Michael.Smith at usace.army.mil> wrote:
>> >> Zach,
>> >> Your DATA statement is almost correct. If you are going to use the
>> >> UNIQUE keyword (for supporting queries), you must put a
>> column name
>> >> after UNIQUE and before the SRID.
>> >> Either of these would work:
>> >> DATA ' GEOM from STATES using UNIQUE ID srid 90112'
>> >> or
>> >> DATA ' GEOM from STATES using srid 90112'
>> >> Assuming you have a column named ID, of course.
>> >> Mike
>> >> Michael Smith
>> >> RSGIS Center
>> >> ERDC - CRREL
>> >> US Army Corps of Engineers
>> >> On 11/17/08 8:21 PM, "zach cruise" <zachc1980 at gmail.com> wrote:
>> >>> troubleshooting info on 4.8 box with
>> /ignored-libmap/oracle10g/libmap.dll:
>> >>> msOracleSpatialLayerOpen called with: GEOMETRY from STATES using
>> >>> unique srid 90112 msOracleSpatialLayerOpen. Shared connection not
>> >>> ) msOracleSpatialLayerFreeItemInfo was called.
>> >>> parsing OracleSpatial DATA variable. Must
>> be:'geometry_column FROM
>> >>> table_name [USING UNIQUE <column> SRID srid# FUNCTION]' or
>> >>> 'geometry_column FROM (SELECT stmt) [USING UNIQUE <column> SRID
>> >>> srid# FUNCTION]'. If want to set the FUNCTION statement
>> you can use:
>> >>> FILTER, RELATE, GEOMRELATE or NONE. Your data statement:
>> GEOM from
>> >>> STATES using unique srid 90112
>> >>> On Mon, Nov 17, 2008 at 7:34 PM, zach cruise
>> >>>> btw i got oracle 10 client (with tnsnames.ora) on 4.8 box. other
>> >>>> than returning multiple ora-xxxx errors, 4.8 also returns "web
>> >>>> template error" if i use
>> /ignored-libmap/oracle10g/libmap.dll. this
>> >>>> error is even for only shapefile maps. error goes away when i
>> >>>> switch back to normal libmap.dll.
>> >>>> On Mon, Nov 17, 2008 at 5:56 PM, zach cruise
>> >>>>> looks like mod_fastcgi is not an option with ms4w and oracle 10.
>> >>>>> anyway it had little benefits.
>> >>>>> i now got mapserver 5.2 and 4.8:
>> >>>>> i thought 5.2 had native built-in support for oracle
>> 10, but it is
>> >>>>> giving me "OracleSpatial is not supported" error. i
>> also thought
>> >>>>> 4.8 could get ogr support for oracle 10 by following
>> the steps on
>> http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#ora
>> >> cle-10g>>>
>> >>>>> 4.8 connects, but returns multiple ORA-xxxx errors.
>> >>>>> so:
>> >>>>> do i have to install oracle 10 client locally and make
>> changes to
>> >>>>> httpd.conf for 5.2 to work?
>> >>>>> how do i find correct srid for 4.8 to work? (DATA
>> "GEOMETRY from
>> >>>>> (select GEOMETRY from STATES where NAME = 'New York')") any
>> >>>>> performance difference between native built-in and ogr supports?
>> >>>>> On Fri, Nov 14, 2008 at 6:22 PM, Jeff McKenna
>> >>>>> <jmckenna at gatewaygeomatics.com> wrote:
>> >>>>>> zach cruise wrote:
>> >>>>>>> does current ms4w with fastcgi work with oracle 10?
>> >>>>>>> here're warnings
>> http://www.maptools.org/ms4w/?page=README_INSTALL.html#f-fastcgi
>> http://www.nabble.com/fastcgi-connections-to-Oracle-and-SDE-on-W
>> >>>>>>> indows-to1
>> >>>>>>> 8394152.html
>> >>>>>>> in testing this was successful with PostgreSQL 8.3.1
>> / PostGIS
>> >>>>>>> 1.3.3, but unsuccessful with Oracle 10.2.0.1.0 (Apache logs:
>> >>>>>>> "mod_fcgid: get overlap result error")
>> >>>>>>> if not, any workarounds?
>> >>>>>> I tested and wrote that note...and am not aware of a
>> workaround
>> >>>>>> yet. You should also send this question to the MS4W
>> mailing list (subscribe at:
>> >>>>>> http://lists.maptools.org/mailman/listinfo/ms4w-users)
>> >>>>>> Jeff McKenna
>> >>>>>> FOSS4G Consulting and Training Services
>> >>>>>> http://www.gatewaygeomatics.com/
>> >>>>>> _______________________________________________
>> >>>>>> mapserver-users mailing list
>> >>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
