[mapserver-users] php mapscript objects in session?
Umberto Nicoletti
umberto.nicoletti at gmail.com
Fri Nov 21 08:08:10 EST 2008
On Fri, Nov 21, 2008 at 11:55 AM, Pietro Giannini <pgiannini at bytewise.it> wrote:
> Ciao Umberto,
> excuse me, but your statement has put me in a state of anxiety :)
> Currently I'm involved in an ASP.NET C# mapscript developement, and I use
> extensively the method of saving mapscript object in session.
> Naturally I tested the envirenmnet with a certain number of concurrent
> users, and I don't get any strange issue, like accessing to an object of
> another session.
so, do you share objects (like a mapobj) between sessions (ie:
different requests use the same mapObj instance to perform map
drawing) without locking at application (c# in your case) level?
If the answer is yes you've just been lucky so far as this approach
will surely lead to errors.
> Why do you say this is NOT recommended?
I'm sorry, I can't provide technical arguments right now, but in my
experience (+3years with Java mapscript) this solution proved to be
the most stable.
YMMV.
Ciao,
Umberto
> ciao .......................pg
> Pietro Giannini
> Bytewise srl - Area GIS
> 41°50'38.58"N 12°29'13.39"E
> On Ven, Novembre 21, 2008 10:20, Umberto Nicoletti wrote:
>> And even if it was possible it is NOT recommended to reuse mapscript
>> objects across requests, see my previous post on the "Mapserver Thread
>> Safety" thread earlier this week.
>> Umberto
>> On Fri, Nov 21, 2008 at 10:13 AM, Pietro Giannini <pgiannini at bytewise.it>
>> wrote:
>>> according to my little knowledge, php cannot store an instance of an
>>> object in a session, only primitives variables like strings, integers,
>>> floats and arrays (asp.net instead can).
>>> for your app you must save the context (mapfile path, the extent, the
>>> layers status etc.), and re-instance the map object at each postback.
>>> hth
>>> ........................pg
>>> Pietro Giannini
>>> On Ven, Novembre 21, 2008 00:33, Christopher Condit wrote:
>>>> Hi-
>>>> I'm using ms4w 2.2.7 and I've run into a problem. Ideally I'd like to
>>>> create the MapScript map object and store it in the session:
>>>> $_SESSION['map'] = ms_newMapObj($getMapPath);
>>>> This works fine for the that page, for the first call, but when I
>>>> attempt to reference it later I get a PHP error:
>>>> Fatal error: Object has an invalid _handle_ property
>>>> Am I missing something here?
>>>> Thanks,
>>>> -Chris
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
