[MAPSERVER-USERS] CLASSITEM and EXPRESSION issue in trunk?
Pål Kristensen
pal.kristensen at statkart.no
Fri Nov 21 09:35:29 EST 2008
Hi!
I've compiled 5.3-dev from trunk yesterday and got some trouble with some
mapfiles that works well on 5.2. The problem is that the EXPRESSION
parameter in the CALSS object does not work with direct string comparison.
Her are some examples:
Does NOT work: (This is the original layer definition from the 5.2 mapfile)
LAYER
CLASSITEM "maxhoyde"
CLASS
NAME "test"
EXPRESSION "600"
END
END
Using RegEx instead WORKS:
LAYER
CLASS
NAME "test"
EXPRESSION /600/
END
END
Using logical expression WORKS:
LAYER
#CLASSITEM "maxhoyde"
CLASS
NAME "test"
EXPRESSION ([makshoyde] == 600)
END
END
The data is stored in PostgreSQL (PostGIS), and the actual field type is
character(5). Anyone have a clue about what is causing this strange
behavior.
Regards,
Pål Kristensen
View this message in context: http://www.nabble.com/CLASSITEM-and-EXPRESSION-issue-in-trunk--tp20622309p20622309.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
