[mapserver-users] boundingboxes
Bob Basques
bob.b at gritechnologies.com
Mon Nov 24 09:33:57 EST 2008
An idea . . .
Sort the database return by the area of the BBOX, with smallest area
first, the first row returned with be the smallest, reverse the sort for
the largest BBOX.
If you are using a Imagemap in the client, the sorting still matter,
since you can effectively stack the output of the imagemap in the same
way. The first item in the imagemap stacking that satisfies the browser
will be read and displayed.
bobb
Florian Thuerkow wrote:
> Hi folks,
> I display several boundingboxes on a map from a PostgreSQL database.
> There is a big boundingbox which contains several
> smaller boundingboxes.
> The User can click on each boundingbox to retrieve further information
> of the boundingbox.
> The Problem now is that the user also retrieve the information
> of the big boundingbox and not only this of the small ones.
> Maybe someone can help me solving this problem?
> Thanks a lot,
> Florian Thuerkow
