[mapserver-users] AGG Rendering
    Andrew Ayre
    andy at britishideas.com
    Thu Apr  2 23:08:18 PDT 2009
Hi! I can't seem to get AGG to work. Currently my output is not
antialiased. Can anyone give me some hints? Thanks!
Note that I have built AGG 2.5 with freetype support. Also note that I
needed two
./configure --with-postgis=/usr/bin/pg_config --with-wfs --with-proj
--with-geos=/usr/bin/geos-config --with-gd=/usr/local/ --with-jpeg
--with-ogr=/usr/bin/gdal-config --with-gdal=/usr/bin/gdal-config
--with-agg=/usr/local/src/agg-2.5 --with-freetype
MapServer is now configured for
  -------------- Compiler Info -------------
   C compiler:                gcc -O2 -fPIC -Wall
   C++ compiler:              g++ -O2 -fPIC -Wall
   Debug:
   Generic NINT:
  -------------- Renderer Settings ---------
   zlib support:              -DUSE_ZLIB
   png support:
   palette rgba png support:
   jpeg support:
   iconv support:             -DUSE_ICONV
   AGG support:               -DUSE_AGG
   AGG Freetype support:      agg_font_freetype.o
   Ming(flash) support:
   PDFLib support:
  -------------- Support Libraries ---------
   Proj.4 support:            -DUSE_PROJ
   Libxml2 support:
   FriBidi support:
   Curl support:
   FastCGI support:
   Threading support:
   GEOS support:              -DUSE_GEOS
  -------------- Data Format Drivers -------
   native tiff support:
   PostGIS support:           -DUSE_POSTGIS
   EPPL7 support:             -DUSE_EPPL
   ArcSDE support:
   OGR support:               -DUSE_OGR
   GDAL support:              -DUSE_GDAL
   Oracle Spatial support:
  -------------- OGC Services --------------
   WMS Server:                -DUSE_WMS_SVR
   WMS Client:
   WFS Server:                -DUSE_WFS_SVR
   WFS Client:
   WCS Server:
   SOS Server:
  -------------- MapScript -----------------
   PHP MapScript:             no
./mapserv.cgi -v
MapServer version 5.2.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=GEOS INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
OUTPUTFORMAT
   NAME 'AGG_Q'
   DRIVER AGG/PNG
   IMAGEMODE RGB
   FORMATOPTION "QUANTIZE_FORCE=ON"
   FORMATOPTION "QUANTIZE_DITHER=OFF"
   FORMATOPTION "QUANTIZE_COLORS=256"
END
This is the error message I get:
loadOutputFormat(): General error message. OUTPUTFORMAT clause
references driver AGG/PNG, but this driver isn't configured.
Andy
Andy
PGP Key ID: 0xDC1B5864
More information about the MapServer-users
