[mapserver-users] Using the SQL Server 2008 Plugin with a
Geography column
Tamas Szekeres
szekerest at gmail.com
Fri Apr 3 05:15:04 EDT 2009
The MSSQL 2008 driver only compatible with the Geometry data type at the
moment. In case if the Geography data type is used the spatial filter should
also be specifyed as Geography which is not the case in the current
implementation. You might want to submit a ticket describing the issue and
we could probably get it implemented in a future release.
Best regards,
Tamas
2009/4/2 joncoign <jncoign at knology.net>
> To clarify I have a column in SQL 2008 of type geography that I would like
> to use in map server. I have been able to do this using the OGR ODBC driver.
> However, when trying to use the Native SQL 2008 driver that has been added
> to MS4W 2.3.1 I get the error message "sys.geometry is incompatible with
> sys.geography" when executing the query captured by profiling the database
> request.
> It appears as though the SQL 2008 driver either assumes that it will always
> (and only) be used against geometry columns or there is a configuration
> setting I that I can use to tell it that the internal datatype is geography
> and as such builds the WHERE clause using the geomertry type for the
> bounding box filter.
> SQL Excerpt:
> the_geom.STIntersects(Geometry::STGeomFromText('POLYGON(...)') = 1
> where in this case the_geom is a Geography column that cannot be used in an
> STIntersects call with a Geometry object.
> I am hoping someone can tell me about the configuration option to change
> this behavior or confirm that it does not exist so we can discuss the
> possibility of adding such an option.
> Let me know if you need additional details.
> There are two ways to define an object spatially in 2008 one as type
> geometry and one as geography.
> http://n2.nabble.com/Using-the-SQL-Server-2008-Plugin-with-a-Geography-column-tp2565867p2575468.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090403/8bbe3017/attachment-0001.html
