[mapserver-users] Using JSP with ms4w
Venkat Rao Tammineni
vtammineni at roulacglobal.com
Fri Apr 17 03:15:25 EDT 2009
Have a look into the sample code .. Refer some urls in mapserver portal
"how to compile mapserver with java".But basically I m not java developer.I
am into C#.net.May the below sample can help you at least it guides you.
<%@page contentType="text/html; charset=GB2312" language="java" %>
<%@page import="edu.umn.gis.mapscript.*" %>
<%@page import="java.util.Iterator, java.util.ArrayList"%>
<%@page import="java.util.Date"%>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML>
<HEAD>
<TITLE> my first mapserver-webgis Good-luck </TITLE>
</HEAD>
<BODY>
<FORM METHOD=POST ACTION="index.jsp">
static int i=0;
mapObj map;
String vMapFile="";
String vScaleBarFile="";
String vLengdBarFile="";
String vReferenceFile="";
double rodio=1;
map = new mapObj ("D:/webapps/mapserver/tutorial.map");
if(map==null)
System.out.println("!ok");
else
if(request.getParameter("rodio")!=null)
if(request.getParameter("rodio")!="")
rodio=Double.parseDouble(request.getParameter("rodio"));
rectObj ro=map.getExtent();
double xw=ro.getMaxx()-ro.getMinx();
double yw=ro.getMaxy()-ro.getMiny();
double cx=(ro.getMaxx()+ro.getMinx())/2;
double cy=(ro.getMaxy()+ro.getMiny())/2;
double newxw=xw*rodio;
double newyw=yw*rodio;
double maxx=cx+newxw/2;
double minx=cx-newxw/2;
double maxy=cy+newyw/2;
double miny=cy-newyw/2;
map.setExtent( minx, miny, maxx, maxy);
System.out.println("minx:"+minx);
System.out.println("miny:"+miny);
System.out.println("maxx:"+maxx);
System.out.println("maxy:"+maxy);
map.setImagecolor(new colorObj(10,128,98,13));
imageObj imagen=map.draw();
//imagen.setImageDir("/tmp");
Date dt=new Date();
vMapFile="output/tangnf"+(dt.getTime())+".png";
// map.embedScalebar(imagen);
imagen.save(vMapFile,map);
scalebarObj scalebar=map.getScalebar();
scalebar.setHeight(10);
scalebar.setWidth(200);
scalebar.setBackgroundcolor(new colorObj(0,255,0,13));
scalebar.setColor(new colorObj(230,0,0,13));
scalebar.setImagecolor(new colorObj(255,255,255,13));
scalebar.setOutlinecolor(new colorObj(0,230,255,13));
//scalebar.setStyle(3);
scalebar.setUnits(3);
scalebar.setIntervals(3);
//scalebar.setLabel(new labelObj
imageObj Scalebarimage=map.drawScalebar();
vScaleBarFile="output/scalebar"+(dt.getTime())+".jpg";
Scalebarimage.save(vScaleBarFile,map);
legendObj legend=map.getLegend();
legend.setHeight(200);
legend.setWidth(100);
System.out.println(legend.getLabel().getEncoding());
imageObj Legendimage=map.drawLegend();
vLengdBarFile="output/Legend"+(dt.getTime())+".png";
Legendimage.save(vLengdBarFile,map);
int layerCount=map.getNumlayers();
for(int i=0;i<layerCount;i++)
layerObj layer=map.getLayer(i);
System.out.println("layer"+(i)+":"+layer.getName());
System.out.println("layerCount:"+layerCount);
referenceMapObj referenceMap=map.getReference();
referenceMap.setHeight(200);
referenceMap.setWidth(200);
imageObj ReferenceImg=map.drawReferenceMap();
vReferenceFile="output/Reference"+(dt.getTime())+".png";
ReferenceImg.save(vReferenceFile,map);
System.out.println("test");
<table border=1>
<tr><td>
<INPUT TYPE="text" NAME="rodio" value="<%=rodio%>" id="rodio" >
</td>
<td>
<INPUT TYPE="submit" value="test">
</td>
<tr><td width=80 >
<INPUT NAME="ScaleBar" TYPE="image" SRC="<%=vScaleBarFile%>" border=1>
<!-- <img SRC="<%=vScaleBarFile%>" border=0 width=100 height=17></img> -->
</td>
</tr>
<tr><td>
<INPUT NAME="imgMap" TYPE="image" SRC="<%=vMapFile%>" width=600 height=400
border=0>
</td>
</tr>
<tr><td>
<INPUT NAME="imgLengd" TYPE="image" SRC="<%=vLengdBarFile%>" border=0>
</td>
<td>
<INPUT NAME="vReferenceF" TYPE="image" SRC="<%=vReferenceFile%>" border=0>
</td>
</tr>
</table>
</FORM>
</BODY>
</HTML>
Thanks,
Venkat
GIS Developer
Hyderbad
India
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mukul Gupta
Sent: Friday, April 17, 2009 12:25 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Using JSP with ms4w
Hi
I am new to this mapserver thing and cant figure out how to work with JSP
instead of PHP for my GIS application development.I already have Tomcat 6
installed and its working fine. Tell me how to configure it so that it will
work with ms4w.Please also suggest some tutorials and examples for me to
start working.
--Mukul
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090417/bc8ca30b/attachment-0001.html
