[mapserver-users] GET parameter in MapServer query
A387
adri.kodde at gmail.com
Fri Apr 17 04:46:59 EDT 2009
Hi all,
This is my first post in the mapserver mailinglist.
I'm having problems with querying Oracle Spatial. For example, this is my current query:
DATA "GEOM FROM (SELECT * FROM WIJK_2008 WHERE datum LIKE '%-08') USING SRID 28992"
What I want now, is that if I access my file by the following URL, is that the LIKE values will be changed by the parameters given in the URL.
Current: http://localhost/cgi-bin/mapserv.exe?map=../../apps/wijk/htdocs/wijk_2008_gen.map&layer=wijkgrenzen&mode=map&program=../cgi-bin/mapserv.exe
What I want:
http://localhost/cgi-bin/mapserv.exe?map=../../apps/wijk/htdocs/wijk_2008_gen.map&layer=wijkgrenzen&mode=map&program=../cgi-bin/mapserv.exe&year=2008.
Could you give me a heads up, about if this is possible and how to make my mapfile dynamically?
View this message in context: http://n2.nabble.com/GET-parameter-in-MapServer-query-tp2644877p2644877.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
