[mapserver-users] MapServer graphics sandbox windows binary
packages available
thomas bonfort
thomas.bonfort at gmail.com
Sun Apr 19 14:40:26 EDT 2009
Thank you Tamas for preparing this.
It should be noted that while the opengl code compiles, it is not
ready for testing yet.
the cairo code should be at least able to produce png, pdf and svg
output, although not everything is implemented yet.
best regards,
Thomas
On Sun, Apr 19, 2009 at 20:08, Tamas Szekeres <szekerest at gmail.com> wrote:
> Hi All,
> I've added the binaries from the graphics sandbox (with cairo and opengl
> support) to my regular builds compiled automatically from the SVN in every
> day.
> The ready to use binary packages are available to download from here:
> http://vbkto.dyndns.org:1280/sdk/index.html
> You can also use the SDKs here to compile the graphics sandbox for debug
> purposes by using the following steps:
> 1. Download the SDK which suits best with your compiler/architecture
> 2. Extract the package into a directory (ie. C:\builds\release-1400-dev)
> 3. Check out the graphics sandbox from SVN into the build directory (ie.
> C:\builds\release-1400-dev\graphics)
> 4. Open a Visual Studio Command Prompt and type:
>> cd C:\builds
>> nmake ms DEBUG=YES MS_CAIRO=YES MS_OGL=YES MS_DIR=graphics
> the compiled files are then located in the
> C:\builds\release-1400-dev\release-1400\bin
> It must be noted that the contents in the sandbox is very experimental any
> testing and feedback on this stuff is highly appreciated.
> Best regards,
> Tamas
> mapserver-users at lists.osgeo.org
