[mapserver-users] getAllLayerNames crashes PHP MapScript?
kreshna_iceheart at yahoo.com
Wed Jun 17 03:28:46 EDT 2009
I have the following codes in my web map application:
$GLOBALS["layer_names"] = $GLOBALS["map"]->getAllLayerNames();
When I ran the web map application through browser, Windows gave me the following error message:
CGI / FastCGI has encountered a problem and needs to close. We are sorry for the inconvenience.
Also, the browser showed the following error message:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, admin at local.domain and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
First I thought it was because I used global variables, but I changed the variables into non-global variables, and the error was still there.
I'm using ms4w with MapServer version 5.0.2. The PHP version is 5.2.5 (cli) (built: Nov 8 2007 23:18:51), with Zend Engine v2.2.0. What could be wrong?
Thanks,
-Kresh
PS: the following is the result of phpinfo_mapscript.php
System Windows NT TOSHIBA-FA8C99F 5.1 build 2600
Build Date Nov 8 2007 23:18:08
Configure Command cscript /nologo configure.js "--enable-snapshot-build" "--with-gd=shared"
Server API CGI/FastCGI
Virtual Directory Support enabled
Configuration File (php.ini) Path C:\WINDOWS
Loaded Configuration File D:\ms4w\Apache\cgi-bin\php.ini
PHP API 20041225
PHP Extension 20060613
Zend Extension 220060519
Debug Build no
Thread Safety enabled
Zend Memory Manager enabled
IPv6 Support enabled
Registered PHP Streams php, file, data, http, ftp, compress.zlib
Registered Stream Socket Transports tcp, udp
Registered Stream Filters convert.iconv.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, zlib.*
This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.2.0, Copyright (c) 1998-2007 Zend Technologies
