[mapserver-users] long expression statement
doesn'tworkanymore
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Nov 17 01:20:58 EST 2009
See ticket 2123 for an explanation of how this bug occurred... (http://trac.osgeo.org/mapserver/ticket/2123)
Steve
>>> "Steve Lime" <Steve.Lime at dnr.state.mn.us> 11/17/09 12:01 AM >>>
I was just checking out Rafael's test case. I thought it might be a lexer buffer length
issue but at lease with my version of flex the entire expression string gets loaded. In
the test case the expression is 23K long, a good test.
Further testing shows the problem is in the parser (bison). It seems to have a maximum
token size of 1024 (including \0) so anything after character 1023 is truncated.
Now, how to fix...
Steve
>>> "Worth Lutz" <wal3 at mindspring.com> 11/12/09 4:22 PM >>>
Steve,
Did the test case Rafael Szajbel sent you which show this problem? I now
have a major problem in my new PHP mapscript application with this. I can
get lots of parcels selected but once the number gets over about 94 with
each parcel id being 10 characters long, I start loosing the end. I can
confirm that the last ones are missing. My test case does not work for
postgres layers or shapefiles so the problem must be in the expression
handling on mapserver. I am inserting a class in my layer and setting the
expression in the form "([tag]' in '1324567543,1234567645,8766544444')".
Once I exceed a certain limit, parcels are not being highlighted.
I think I could peel out a test case if you have not seen it yet.
-----Original Message-----
From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Sent: Friday, October 23, 2009 3:34 PM
To: 'Mapserver Mailinglist ENG'; Worth Lutz; 'Rafael Szajbel'
Subject: RE: [mapserver-users] long expression statement doesn't workanymore
As I mentioned earlier, I'd love a test case!
>>> On 10/23/2009 at 1:28 PM, in message
<2001F78572A34911ACFBA0BF7CD874CC at Worthlaptop>, "Worth Lutz"
<wal3 at mindspring.com> wrote:
> I'm seeing the same (or similar) problem.
> First I query a MSsql database and get a result set. The parcel ids from
> the result set are inserted into an expression in a class which is
inserted
> into a layer of the map which has its geometry data in a postgres
database.
> (Don't ask why two databases! We hope to move the data soon.) The
parcels
> are then highlighted on the map.
> The problem we are seeing is when there are lots of parcels, the resulting
> map has missing parcels in the highlighted set. My solution to this was
to
> reduce the number of parcels in each class to 100 and insert many
identical
> classes. My results seem more stable but I still have and error when the
> number of parcels exceeds 500 or so. Each parcel id is 9 characters long
> and the form of expression is "([tag] in '123456789,987654321')"
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Steve Lime
> Sent: Wednesday, October 21, 2009 11:20 AM
> To: Mapserver Mailinglist ENG; Rafael Szajbel
> Subject: Re: [mapserver-users] long expression statement doesn't work
> anymore
> Any chance you could create a simple test case showing the problem? The
fact
> it shows some
> features is puzzling. If it was just a matter of the expression getting
> truncated then you should
> see an expression parse error.
> Steve
>>>> Rafael Szajbel <szajbel at widemann.de> 10/21/2009 6:58 AM >>>
> Hello,
> in an older MapServer version (4.10.0) it is possible to use a very long
> Expression or Filter statement.
> Like this one with over 1000 comma separated values:
> EXPRESSION ('[NR]' IN 'ID1,ID2,.................,ID1100')
> This works fine:
> With newer MapServer versions (whether cgi (expression in mapfile) or
> phpmapscript (expression set with setExpression)) like 5.2.1 or 5.6.0
beta3
> only o small part of the polygons appears:
> So is there a limit on expression statement since version 5?
> There are no errors in the log-file with debug set to 5.
> This is my layer definition:
> LAYER
> DATA "shapes/fs.shp"
> NAME "FS"
> STATUS ON
> TYPE POLYGON
> CLASS
> NAME "FS"
> 'ID1,ID2,.............................,ID1100') # <-- of course without
> the points ;)
> STYLE
> COLOR 255 255 200
> OUTLINECOLOR 0 0 0
> END
> END
> END
> Thanks for any hint.
> Rafael
> PS: It is not possible to classify on attributes.
> mapserver-users at lists.osgeo.org
