[mapserver-users] Using nquery/mapxy/TOLERANCE/TOLERANCEUNITS
Brent Fraser
bfraser at geoanalytic.com
Thu Oct 1 13:25:26 EDT 2009
Steve,
So the alternative to using imgxy is to send mapserver:
mapxy and mapext and imgext (where mapext=imgext) and imgsize?
Hmm, I think I tried that, but I'll take a closer look.
Sounds like the better solution is just to change Geomoose to use imgxy.
Thanks!
Brent Fraser
Steve Lime wrote:
> It's possible to use mapxy in conjunction with TOLERANCEUNITS PIXELS but you
> have to understand how pixel size is computed for it to work as expected. The
> assumption is that there's a map associated with the point query and it's defined
> by a map extent, a width and a height.
I thought that was imgext and imgsize?
> So, you'd need to define those somehow
> too. If not explicitly set as part of a query the defaults in the mapfile are used which
> is where things could get convoluted. I can't recall what happens if you define
> mapxy AND mapext with mode=nquery though, which takes precedence in setting
> the query method? (looks ambiguous in the code)
Could be a implementation/support headache...
> Practically speaking, if a query or whatever is associated with a map image regardless
> of client environment I *always* use imgxy, imgext and imgsize and populate those
> from the client and let MapServer do the conversion. Works fine with the environments
> I use frequently (e.g. OL and dBox). This site does it extensively via OL:
I'm off to hack GeoMoose!
> http://www.dnr.state.mn.us/waters/csg/index_beta.html
> Steve
>>>> Brent Fraser <bfraser at geoanalytic.com> 10/01/09 10:51 AM >>>
> I'd like someone to confirm my understanding of using
> nquery/mapxy/TOLERANCE/TOLERANCEUNITS.
> GeoMoose v1.6 sets mapxy and imgext (along with mode=nquery and imgsize) CGI
> variables when doing an "Identify Feature" operation. I'd like to use
> TOLERANCEUNITS PIXELS (and TOLERANCE 3) for my point layer because I think it's
> more intuitive over a range of scales (as opposed to TOLERANCEUNITS METERS,
> TOLERANCE 500).
> This is not possible as using Mapserver's mapxy requires the map file to have
> TOLERANCEUNITS METERS to work properly. If I want to use TOLERANCEUNITS PIXELS,
> I must use imgxy instead of mapxy because mapserver does not do the conversion
> from mapxy mapping coords to imgxy image coords.
> Is this correct?
> Thanks!
> Brent Fraser
> mapserver-users at lists.osgeo.org
