[mapserver-users] JOIN SHP and CSV
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Oct 1 15:08:19 EDT 2009
Hi Stefan: Well, the obvious problem is that you haven't set the join CONNECTIONTYPE. The docs
look to be wrong to me in a couple of ways wrt to CSV joins. The first is the connection type as
mentioned earlier. The second is that CSV join code doesn't use the first row as column names,
instead you refer to the columns by number (1, 2, 3, ..., n). It's a pretty basic implementation
I'll admit.
So, your JOIN block should look something like:
JOIN
NAME "tab"
CONNECTIONTYPE CSV
TABLE "../../../../daten/vektordaten/utm/studios/europa_sonnenstudio.csv"
FROM "NAME"
TO "1"
TYPE ONE-TO-ONE
END
and then in the template you'd use [tab_1], [tab_2], ... to access joined values.
Not sure why the docs are so far off, I'll file a ticket on that.
Steve
>>> Stefan Schantz <sschantz at bfs.de> 09/30/09 7:18 AM >>>
Hello,
although I 've read several informations (in this user list, mapserver
documentation) about joining datas von a csv-file to a shp-file, I still
get the error message "Content-type: application/vnd.ogc.se_xml
msDBFJoinConnect(): Unable to access file.
(../../../../daten/vektordaten/utm/studios/europa_sonnenstudio.csv)"
I 've tried already several things like putting csv-file at the same
place as the mapfile, chmod 777 , but I always got the same message.
Any ideas? Thanks!
My mapfile looks like:
LAYER
NAME "europa"
TYPE POLYGON
STATUS ON
DUMP TRUE
DATA "europa"
JOIN
NAME "tab"
TABLE
FROM "NAME"
TO "NAME"
TYPE ONE-TO-ONE
END
PROJECTION
"init=epsg:4326"
END
METADATA
WMS_SRS "EPSG:25832 EPSG:4326 EPSG:32632 EPSG:31466
EPSG:31467 EPSG:31468"
WMS_TITLE "Sonnenstudio"
WMS_ABSTRACT "blabla"
END
LABELITEM 'NAME'
CLASS
END # CLASS
CLASS
END # CLASS
TEMPLATE "../templates/getFeature_sonnenstudio.html"
The path to the data is
"/daten/vektordaten/utm/studios/europa_sonnenstudio.csv"
303140 -rwxrwxrwx 1 ssh-m gdi 2229 Sep 30 11:27
path to the mapfile is "/data/umn/abc/map/studio.map"
The information of the csv-data is:
ogrinfo europa_sonnenstudio.csv europa_sonnenstudio -summary
INFO: Open of `europa_sonnenstudio.csv'
using driver `CSV' successful.
Layer name: europa_sonnenstudio
Geometry: None
Feature Count: 54
Layer SRS WKT:
(unknown)
TEXT: String (0.0)
DATUM: String (0.0)
The information of the shp-data is:
ogrinfo europa.shp europa -summary
INFO: Open of `europa.shp'
using driver `ESRI Shapefile' successful.
Layer name: europa
Geometry: Polygon
Feature Count: 54
Extent: (-31.265747, 32.397476) - (69.070320, 81.857368)
Layer SRS WKT:
(unknown)
Greetings from the Bavarian-Oktoberfest
Stefan
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
