[mapserver-users] tile4ms - Layer object STATUS
Ted Spradley
tspradley at snoogems.com
Sat Oct 3 00:00:29 EDT 2009
Thank you for taking a look at it!
Still no success displaying with any other STATUS than DEFAULT. Here are
the variations I tried:
Variation 1 - Result: No Layer display at any zoom level
LAYER
NAME "areawater"
STATUS ON
TYPE POLYGON
TILEINDEX "/path/to/areawaterindex"
TILEITEM 'LOCATION'
CLASS
NAME "areawater"
STYLE
COLOR 0 0 255
END
END
End Variation 1
Variation 2 - Result: No Layer Display at any zoom level
LAYER
NAME "areawater"
STATUS ON
TYPE POLYGON
TILEITEM 'LOCATION'
MAXSCALEDENOM 1000000 # Another layer with this same Maxscaledenom did
display
CLASS
NAME "areawater"
STYLE
COLOR 0 0 255
END
END
End Variation 2
Variation 3 - Result: No Layer Display at any zoom level
LAYER
NAME "areawater"
STATUS ON
TYPE POLYGON
TILEITEM 'LOCATION'
CLASS
NAME "areawater"
STYLE
COLOR 0 0 255
END
END
End Variation 3
Variation 4 - Result: Layer Displays upon reaching MAXSCALEDENOM 1000000
LAYER
NAME "areawater"
STATUS DEFAULT
TYPE POLYGON
TILEITEM 'LOCATION'
display
CLASS
NAME "areawater"
STYLE
COLOR 0 0 255
END
END
End Variation 4
Variation 4 displays of course, but so would a regular layer that had not
had a tile index built for it, with the same MAXSCALEDENOM 1000000.
Could it possibly be something in my template?
Thanks again, Ted S.
Mapserver Template
<!-- Mapserver Template -->
<html>
<head>
<title>U.S. Atlas - States, Counties, Area Water</title>
</head>
<body bgcolor="#ffffff">
<div id="main">
<div id="head">
<h2>U.S. Atlas - States, Counties</h2>
</div>
<form method="GET">
<input name="img" type="image" src="[img]" width="80%" height="80%"
border=2> <br />
<input type="submit" value="Redraw"> <br />
[Zoom In <input type="radio" name="zoomdir" value="1" [zoomdir_1_check]>]
[Pan <input type="radio" name="zoomdir" value="0" [zoomdir_0_check]>]
[Zoom Out <input type="radio" name="zoomdir" value="-1" [zoomdir_-1_check]>]
Zoom Size <input type="text" name="zoomsize" size="4" value="2">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="map" value="[map]">
</form>
</div>
</body>
</html>
End Mapserver Template
STATUS OFF means just that.
STATUS ON means, it is available, but has to be requested
STATUS DEFAULT means you're gonna get it no matter what
Given the above three states, you can apply MINSCALEDENOM and
MAXSCALEDENOM. Note that MINSCALE and MAXSCALE are now deprecated.
View this message in context: http://n2.nabble.com/tile4ms-Layer-object-STATUS-tp3758428p3759035.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
