[mapserver-users] tile4ms - Layer object STATUS
James Card
James.Card at calcad.com
Sat Oct 3 00:53:27 EDT 2009
On Fri, 02 Oct 2009 21:00:29 -0700, Ted Spradley <tspradley at snoogems.com>
wrote:
> STATUS ON means, it is available, but has to be requested
The key here, that you may be missing, is that your WMS request must
specify each layer that you want to be included in the map that is
returned. Requesting a map without including the LAYERS parameter will
return only the layers that have STATUS DEFAULT set.
James Card
