[mapserver-users] Problem with configure
Alan Hale
alan.hale at btclick.com
Tue Oct 13 04:03:56 EDT 2009
Hi
Running on CentOS5 I am getting an error with configure relating to gd.
Here is the last part of the output:
MapServer Version from mapserver.h: '5.4.2'
checking if pkg-config path is provided... checking for pkg-config...
/usr/bin/pkg-config
configure: checking where FreeType 2.x is installed...
using libfreetype from -L/usr/local/lib/ -lfreetype
./configure: line 5261: test: too many arguments
configure: checking where Zlib is installed...
checking for zlibVersion in -lz... yes
using libz from system libs (-DUSE_ZLIB).
configure: checking where PNG is installed...
checking for png_init_io in -lpng... yes
using libpng from system libs.
configure: checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
using libjpeg from system libs.
configure: checking where libXpm is installed...
checking for XpmFreeXpmImage in -lXpm... no
XPM (libXpm) library cannot be found, possibly needed for GD
configure: checking where libiconv is installed...
checking for iconv_open in -lc... yes
checking for libiconv_open in -liconv... no
checking for iconv_open in -liconv... no
using libiconv from system libs.
libiconv found. Enabling internationalization (-DUSE_ICONV)
configure: checking for GD 2.0.16 or higher...
checking for gdFontCacheSetup in -lgd... yes
configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/lib/.
Make sure GD 2.0.16 or higher is compiled before calling configure. You
may also get this error if you didn't specify the appropriate location
for one of GD's dependencies (freetype, libpng, libjpeg or libiconv).
And this is my configure line:
./configure --with-ogr=/usr/local/bin/gdal-config
--with-ogr=/usr/local//bin/gdal-config --with-httpd=/usr/sbin/httpd
--with-wfsclient --with-wmsclient --enable-debug
--with-curl-config=/usr/local/bin/curl-config --with-proj=/usr/local
--with-tiff --with-gd=/usr/lib/ --with-jpeg
--with-freetype=/usr/local/lib/ --with-threads --with-php
libgd.so is definitely under /usr/lib/ and the script seems to have
found all the other dependencies listed for GD. Can anyone please advise?
Many thanks
Alan Hale
__________ Information from ESET Smart Security, version of virus signature database 4501 (20091012) __________
The message was checked by ESET Smart Security.
http://www.eset.com
