[mapserver-users] mapserver produces interlaced PNGs even if
I configured the map to output noninterlaced PNGs
Adrian Popa
adrian_gh.popa at romtelecom.ro
Wed Oct 14 10:06:03 EDT 2009
Thanks Jukka,
I added MIMETYPE "image/png2" to my OUTPUTFORMAT and I called with
FORMAT=image/png2, and now, the PNGs are non-interlaced!
I don't really understand what the difference is, but I'm glad it works.
Thanks again... now I only have to figure out why tilecache isn't
working yet...
Rahkonen Jukka wrote:
> Hi,
> It is possible that rendering does not go through agg. I am not sure,
> but perhaps by adding
> to outputformat and calling either &FORMAT=image/png2 or &FORMAT=image/png
> you could do some comparisons.
> -Jukka Rahkonen-
> *L�hett�j�:* mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] *Puolesta *Adrian
> Popa
> *L�hetetty:* 14. lokakuuta 2009 16:36
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> *Aihe:* [mapserver-users] mapserver produces interlaced PNGs even
> if I configured the map to output noninterlaced PNGs
> Hello all,
> My goal is to setup tilecache (which is proving to be a real
> pain), and so far I've noticed that even if I configured my map to
> generate noninterlaced PNGs (instructions here:
> http://www.mapserver.org/faq.html#why-doesn-t-pil-python-imaging-library-open-my-pngs),
> it still generates interlaced PNGs.
> Here is my outputformat (the only one defined) in my map:
> OUTPUTFORMAT
> NAME 'AGG'
> DRIVER AGG/PNG
> IMAGEMODE RGBA
> TRANSPARENT ON
> FORMATOPTION "INTERLACE=OFF"
> END
> The parameters that get sent to my mapserver instance are:
> BBOX |2896046.12635,5831228.011975,2935181.884825,5870363.77045|
> EXCEPTIONS |application/vnd.ogc.se_inimage|
> FORMAT |png|
> HEIGHT |256|
> LAYERS
> |Judete,RuralSate,Rural,Urban,roads,roads-buc,buildings,GranitaJudete|
> MAP |/var/www/html/map/rtc_base.map|
> MAP_IMAGETYPE |agg|
> MAXEXTENT |left-bottom=(20.26,43.16) right-top=(29.7,48.46)|
> MAXRESOLUTION |156543|
> REQUEST |GetMap|
> SERVICE |WMS|
> SRS |EPSG:900913|
> STYLES
> TRANSITIONEFFECT |resize|
> TRANSPARENT |false|
> UNITS |m|
> VERSION |1.1.1|
> WIDTH |256|
> I'm not sure if MAP_IMAGETYPE=agg is the one which selects the
> outputformat or not, but the map seems to be rendered with AGG (I
> could be wrong, of course).
> So, what am I missing here? Is there another parameter that should
> be sent to mapserver to select the outputformat?
> By the way, the image file generated has these properties:
> img.png: PNG image, 256 x 256, 8-bit colormap, interlaced
> Thanks,
> Adrian
Adrian Popa
NOC Division
Network Engineer
Divizia Centrul National de Operare Retea
Departament Transport IP & Metro
Compartiment IP Core & Backbone
Phone: +40 21 400 3099
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091014/5625d71e/attachment.html
