[mapserver-users] mapserver produces interlaced PNGs even if I
configured the map to output noninterlaced PNGs
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Oct 14 09:45:55 EDT 2009
It is possible that rendering does not go through agg. I am not sure, but perhaps by adding
MIMETYPE "image/png2"
to outputformat and calling either &FORMAT=image/png2 or &FORMAT=image/png
you could do some comparisons.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Adrian Popa
Lähetetty: 14. lokakuuta 2009 16:36
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] mapserver produces interlaced PNGs even if I configured the map to output noninterlaced PNGs
Hello all,
My goal is to setup tilecache (which is proving to be a real pain), and so far I've noticed that even if I configured my map to generate noninterlaced PNGs (instructions here: http://www.mapserver.org/faq.html#why-doesn-t-pil-python-imaging-library-open-my-pngs), it still generates interlaced PNGs.
Here is my outputformat (the only one defined) in my map:
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGBA
TRANSPARENT ON
FORMATOPTION "INTERLACE=OFF"
END
The parameters that get sent to my mapserver instance are:
BBOX 2896046.12635,5831228.011975,2935181.884825,5870363.77045
EXCEPTIONS application/vnd.ogc.se_inimage
FORMAT png
HEIGHT 256
LAYERS Judete,RuralSate,Rural,Urban,roads,roads-buc,buildings,GranitaJudete
MAP /var/www/html/map/rtc_base.map
MAP_IMAGETYPE agg
MAXEXTENT left-bottom=(20.26,43.16) right-top=(29.7,48.46)
MAXRESOLUTION 156543
REQUEST GetMap
SERVICE WMS
SRS EPSG:900913
STYLES
TRANSITIONEFFECT resize
TRANSPARENT false
UNITS m
VERSION 1.1.1
WIDTH 256
I'm not sure if MAP_IMAGETYPE=agg is the one which selects the outputformat or not, but the map seems to be rendered with AGG (I could be wrong, of course).
So, what am I missing here? Is there another parameter that should be sent to mapserver to select the outputformat?
By the way, the image file generated has these properties: img.png: PNG image, 256 x 256, 8-bit colormap, interlaced
Thanks,
Adrian
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091014/d1b4137e/attachment-0001.html
