[mapserver-users] Installing PHP Mapscript
Alan Hale
alan.hale at btclick.com
Thu Oct 15 16:01:34 EDT 2009
Many thanks Alan - I found php-devel in the yum repository on Centos5
and this seems to install a PHP5.2 version. Mapserver configure will
produce a mapscript sub-directory with this though, worryingly perhaps,
with a "make" in the mapscript directory the php_mapscript.so is
generated in a further sub-directory named php3! Hopefully it will be OK.
Alan Boudreault wrote:
> If your PHP if pre-installed.... you'll need to install the "developpement"
> package... which contain header files etc..
> In example: the php5 developpement package on a Ubuntu distribution is called:
> php5-dev
> Alan
> On October 15, 2009 11:37:07 am Alan Hale wrote:
>> I'm a little confused by this. If I understand correctly the mapserver
>> configure script will generate a php_mapscript.so if you use
>> --with-php=DIR. But it seems DIR here is the directory of PHP source.
>> What if PHP is pre-installed? Is this possible to do? Or am I completely
>> misunderstanding?
>> Many thanks
>> Alan Hale
>> __________ Information from ESET Smart Security, version of virus signature
>> database 4510 (20091015) __________
>> The message was checked by ESET Smart Security.
>> http://www.eset.com
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
__________ Information from ESET Smart Security, version of virus signature database 4511 (20091015) __________
http://www.eset.com
