[mapserver-users] Scale dependant image tile
bbarrett
brian at zetica.com
Mon Oct 19 09:59:26 EDT 2009
Hello,
I have recently started using mapserver and ran out of ideas with this
problem.
I have three maps for the same location that I wish to be visible at
different scales (but in the same map layer). Each map comes as 4 or 5 tif
files. I have created a tileindex shapefile for each map using gdaltindex. I
have then created a tileindex shapefile that references each of these using
tile4ms
I had expected the following code to do the trick:
LAYER
NAME "maps"
TILEINDEX "D:\path_to_my_files\maps.shp"
TILEITEM "LOCATION"
TYPE RASTER
STATUS ON
CLASSITEM "LOCATION"
CLASS # 1-10000
EXPRESSION '/1-10000/' # 1:10000 scale map tileindex has 1-10000 in file
path
MINSCALEDENOM 0
MAXSCALEDENOM 6000
END
CLASS # 1-25000
EXPRESSION '/1-25000/' # 1:25000 scale map tileindex has 1-10000 in file
path
MINSCALEDENOM 6000
MAXSCALEDENOM 20000
END
CLASS # 1-50000
EXPRESSION '/1-50000/' # 1:50000 scale map tileindex has 1-10000 in file
path
MINSCALEDENOM 20000
END
END
Can anyone help me to get this scale dependant map that I desire please?
Thanks
Brian
View this message in context: http://n2.nabble.com/Scale-dependant-image-tile-tp3849182p3849182.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
