[mapserver-users] Tiled PNG doesn't work for WCS (and WMS)
Steven M. Ottens
steven.ottens at geodan.nl
Tue Oct 20 10:52:55 EDT 2009
Hi all,
Thanks to Frank the problem was drilled down to the way the relative
paths where defined in the index shapefile. Using absolute paths in
gdaltindex did the trick.
Unfortunately Geoserver 1.7.6 is faster on the same machine, with the
same dataset as Mapserver 5.0.2 :(
http://bit.ly/W02ka
vs
http://bit.ly/2sXA68
Thanks for all the help
Steven
On Oct 20, 2009, at 12:34 PM, Milo van der Linden wrote:
> Steven,
> - tiled png should not be a problem, I use that often.
> - It would be good to also set "wms_extent" in your layer defs
> - I think that setting the wcs_srs to multiple srs-es at the Layer
> Level
> is not how it should be done. Use a single srs there that
> corresponds to
> the wcs_extent or I guess you will have issues. Set the multiple
> srs-es
> at the wcs_srs and wms_srs on the *MAP* level
> Good luck! And send my regards to Mvexel ;-)
> Steven M. Ottens schreef:
>> Hi all,
>> I'm trying to setup a WCS with a series of PNGs with world files.
>> I've
>> indexed them with gdaltindex.
>> When I do a WCS getCoverage or a WMS getMap request I get a white
>> image. However when I configure mapserver to use only one tile as
>> datasource I get an image (black and white in WCS, color in WMS).
>> Working singletile datasource WMS: http://bit.ly/smpyA
>> Working singletile datasource WCS: http://bit.ly/1hXghB
>> not working tiled datasource WMS: http://bit.ly/2k5J11
>> I'm running Mapserver 5.0.2 on windows
>> I've tried to convert the PNGs to geotiff, but that didn't matter.
>> I've tried using Geoserver and there it does work, so the data
>> appears
>> to be correct.
>> Does mapserver support tiled PNGs?
>> Does it support it for WCS?
>> Regards,
>> Steven
>> The configuration for the two layers::
>> single tiledatasource:
>> LAYER
>> NAME vec200tile
>> METADATA
>> "wcs_label" "Swiss Topo Vec200 rendering for Tripod"
>> ### required
>> "wcs_rangeset_name" "Vector200Range" ### required
>> to support DescribeCoverage request
>> "wcs_rangeset_label" "Vec200" ### required to
>> "wcs_extent" "463179.500000 44100.500000
>> 853179.500000 324100.500000" ### required for tiled datasets [MVEXEL]
>> "wcs_res" "1 1" ### from gdalinfo,
>> undocumented metadata element
>> "wcs_size" "10000 10000" ### from
>> gdalinfo, undocumented metadata element
>> "wcs_srs" "EPSG:21781 EPSG:3035"
>> END
>> EXTENT 463179.500000 44100.500000 853179.500000 324100.500000
>> TEMPLATE "blank.html"
>> TYPE RASTER
>> UNITS METERS
>> STATUS ON
>> data "RT_Vec200_1500/1.0/vec200_1500_0_108.png"
>> PROJECTION
>> "init=epsg:21781"
>> END
>> DUMP TRUE ### required
>> END
>> tiled datasource:
>> LAYER
>> NAME vec200
>> METADATA
>> ### required
>> "wcs_srs" "EPSG:27181 EPSG:3035"
>> END
>> TYPE RASTER
>> UNITS METERS
>> STATUS ON
>> TILEINDEX RT_Vec200_1500/1.0/sh1.0.shp
>> TILEITEM "filename"
>> PROJECTION
>> "init=epsg:21781"
>> END
>> END
Steven M. Ottens -==- http://research.geodan.nl/
