[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
Daniel Walton
dgwalton at gmail.com
Thu Oct 22 10:40:52 EDT 2009
Paul,
I got various errors with MapServer running in IIS 7.5 until I installed the
latest build of PHP. Don't know if you've done that already, but I thought I
would mention it.
Regards,
Dan Walton
gisfiretools.com
On Thu, Oct 22, 2009 at 9:29 AM, Paul james <pauljame at gmail.com> wrote:
> Hi Tamas!
> Thanks...
> Yes, thats working on Windows 2003/XP...
> The problem is happening only on Windows 7 (IIS 7.5) now...
> HTTP Error 502.2 - Bad Gateway
> Do you have any idea what is that? Its work fine with postgis...
> Paul
> On Wed, Oct 21, 2009 at 5:00 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Paul,
>> I've set up your data but it works for me:
>> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=mssql2008.map
>> tried with the following binaries:
>> http://vbkto.dyndns.org/sdk/release-1500-gdal-1-6-mapserver-5-4.zip
>> http://vbkto.dyndns.org/sdk/release-1500-gdal-mapserver.zip
>> My mapfile:
>> MAP
>> NAME "SQL2008"
>> STATUS ON
>> SIZE 500 500
>> IMAGETYPE PNG
>> IMAGECOLOR 254 254 254
>> EXTENT -79.7892 -44.2426 -24.9958 -9.11775
>> LAYER
>> NAME "tblGeo_AmericaSul"
>> TYPE POLYGON
>> CONNECTIONTYPE PLUGIN
>> PLUGIN "msplugin_mssql2008.dll"
>> CONNECTION
>> "server=.\MSSQLSERVER2008;database=Maps;Integrated Security=true"
>> DATA "the_geom from tblGeo_AmericaSul USING UNIQUE
>> CodigoAmericaSul USING SRID=0"
>> STATUS DEFAULT
>> CLASS
>> STYLE
>> COLOR 255 0 0
>> END
>> END
>> END
>> END
>> Best regards,
>> Tamas
>> 2009/10/21 Paul james <pauljame at gmail.com>
>> Tamas, the actual error generated is:
>>> The specified CGI application misbehaved by not returning a complete set
>>> of HTTP headers. The headers it did return are "".
>>> Using Windos 7 (IIS 7)
>>> Testing on Windows 2003, I got just a Blank image (no error message)...
>>> You can use the same mssql2008 data I sended you last time...
>>> Paul
>>> On Tue, Oct 20, 2009 at 4:56 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>> Paul,
>>>> I couldn't reproduce your problem by using my data and the recent
>>>> mapserv version.
>>>> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=sql2008.map
>>>> Could you provide your data for testing?
>>>> Best regards,
>>>> Tamas
>>>> 2009/10/20 Paul james <pauljame at gmail.com>
>>>> Hello Tamas
>>>>> Did you test that?
>>>>> Paul
>>>>> On Mon, Oct 19, 2009 at 3:40 PM, Paul james <pauljame at gmail.com>wrote:
>>>>>> Testing :
>>>>>> http://localhost/cgi-bin-54/mapserv.exe?map=C:/Mapserver/Mapfile/map.map&mode=map
>>>>>> Using Postgis connection works fine with same setup...
>>>>>> Using that mapfile with MAPSCRIPT/C# works fine as well...
>>>>>> The problem is CGI + MSSQL2008 Plugin
>>>>>> Mapfile:
>>>>>> MAP
>>>>>> EXTENT -79.7892 -34.2426 -24.9958 6.11775
>>>>>> FONTSET "..\Fontes\Fontes.txt"
>>>>>> IMAGECOLOR 230 254 254
>>>>>> IMAGETYPE png
>>>>>> SIZE 400 200
>>>>>> STATUS ON
>>>>>> UNITS dd
>>>>>> NAME "Geral"
>>>>>> OUTPUTFORMAT
>>>>>> NAME "png"
>>>>>> MIMETYPE "image/png"
>>>>>> DRIVER "GD/PNG"
>>>>>> EXTENSION "png"
>>>>>> IMAGEMODE "PC256"
>>>>>> TRANSPARENT TRUE
>>>>>> END
>>>>>> PROJECTION
>>>>>> 'proj=longlat'
>>>>>> 'ellps=WGS84'
>>>>>> 'datum=WGS84'
>>>>>> 'no_defs'
>>>>>> END
>>>>>> WEB
>>>>>> IMAGEPATH 'C:\map\temp'
>>>>>> IMAGEURL '/tmp/'
>>>>>> QUERYFORMAT text/html
>>>>>> LEGENDFORMAT text/html
>>>>>> BROWSEFORMAT text/html
>>>>>> END
>>>>>> LEGEND
>>>>>> STATUS ON
>>>>>> KEYSIZE 18 12
>>>>>> KEYSPACING 10 5
>>>>>> IMAGECOLOR 255 255 255
>>>>>> LABEL
>>>>>> TYPE BITMAP
>>>>>> SIZE MEDIUM
>>>>>> COLOR 0 0 89
>>>>>> END
>>>>>> TEMPLATE "..\template.html"
>>>>>> END
>>>>>> QUERYMAP
>>>>>> COLOR 255 0 0
>>>>>> SIZE -1 -1
>>>>>> STATUS ON
>>>>>> STYLE hilite
>>>>>> END
>>>>>> REFERENCE
>>>>>> IMAGE "..\reference.png"
>>>>>> STATUS on
>>>>>> SIZE 221 150
>>>>>> MINBOXSIZE 5
>>>>>> MAXBOXSIZE 150
>>>>>> COLOR -1 -1 -1
>>>>>> OUTLINECOLOR 255 0 0
>>>>>> MARKERSIZE 8
>>>>>> END
>>>>>> LAYER
>>>>>> NAME test
>>>>>> GROUP "tests"
>>>>>> TYPE POLYGON
>>>>>> STATUS ON
>>>>>> CONNECTION "server=x;Integrated
>>>>>> Security=false;database=x;uid=x;pwd=x"
>>>>>> DATA "the_geom from viwgeo_paisbrasil USING UNIQUE oid USING SRID=0"
>>>>>> CLASS
>>>>>> COLOR 255 200 255
>>>>>> END
>>>>>> END
>>>>>> END
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091022/d11add87/attachment-0001.html
