[mapserver-users] TileCache 2.10 - MapServer 5.2
Maria Neywell
maria.neywell at gmail.com
Wed Oct 21 03:21:06 EDT 2009
Hi Jukka,
I don't have generated tiles.
I simply want to get, for example, a WMS layer that* *uses tilecache when I
need to display it.
Regards,
Maria
2009/10/20 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Hi,
> Could you explain bit more clear what do you want to do? Do I undestand
> right that you have tilecache running and you have generated the tiles? And
> now you want to read those tiles with Mapserver, and push them out from
> Mapserver non-tiled, for example through WMS service, through WCS, of
> through Mapserver cgi?
> -Jukka Rahkonen-
> Maria Neywell wrote:
> Johan,
> Thanks for your attention,
> In my MapFile I tried to configure a layer with TileCache as follows :
> LAYER
> DATA "myShape.shp"
> CONNECTION "http://localhost/tilecache/tilecache.cgi
> CONNECTIONTYPE WMS
> END
> But it doesn't work.
> Has someone already been successful with a similar configuration?
> Regards,
> Maria
> 2009/10/19 Johan Ruiter <j.ruiter at geon.nl>
> > Maria,
> > In that case I can't help you out. Hopefully someone else does.
> > Regards,
> > Johan
> > *Van:* Maria Neywell [mailto:maria.neywell at gmail.com]
> > *Verzonden:* maandag 19 oktober 2009 14:51
> > *Aan:* Johan Ruiter
> > *CC:* mapserver-users at lists.osgeo.org
> > *Onderwerp:* Re: [mapserver-users] TileCache 2.10 - MapServer 5.2
> > Thanks for your answer,
> > I did it too with OpenLayers, but I my case,
> > I don't want use OpenLayers.
> > The question is : How to configure MapServer or the mapfile or both to
> > use tilecache ? and display the layer without using an OpenLayers layer
> > configured with tilecache ?
> > Regards,
> > Maria
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091021/2303b71e/attachment.html
