[mapserver-users] roadlines issue
Pavel Iacovlev
iacovlev.pavel at gmail.com
Wed Oct 21 09:52:22 EDT 2009
Yes http://mapserver.org/optimization/vector.html this is described
correctly but it's not your case because you are NOT filtering SOME of
the data you just read ALL the data from 2 layers. I sort if you use
ALL the data from that layer there is no point in splitting.
On Wed, Oct 21, 2009 at 2:30 PM, Raivo Alla <snaperski at gmail.com> wrote:
> Hey,
> thank You. I was thinking that pre-splitting large datasets would be a
> good optimization
> step as suggested here: http://mapserver.org/optimization/vector.html
> Have to try and compare ;)
> Raivo
> On Wed, Oct 21, 2009 at 11:45 AM, Pavel Iacovlev
> <iacovlev.pavel at gmail.com> wrote:
>> First if you have 2 layers for roads like highways.shp and
>> secondary.shp (for example) if you make one shape roads.shp file with
>> the a field "type" performance will actually improve.
>> You can see a great example how to render street data (openstreetmap
>> data in this case) here:
>> http://trac.osgeo.org/mapserver/wiki/RenderingOsmData
>> On Wed, Oct 21, 2009 at 10:16 AM, Raivo Alla <snaperski at gmail.com> wrote:
>>> Hello,
>>> the problem I have right now with mapserver is how to display roads
>>> that must be displayed from different layers in a mapfile,
>>> but should have nice joining with each other. Problem is shown here
>>> (red arrows):
>>> http://picasaweb.google.com/snaperski/Ort#5394941894576868946
>>> Desired situation with using multiple mapserver layers is marked with red ring.
>>> If I would use just one massive shapefile and take it as a datasource
>>> in one layer only (instead using multiple shapefiles/layers
>>> drawing highways, streets), then performance will suffer.
>>> Is there any solution to this, ie declaring DATA kayword in a CLASS
>>> section? :) Or something so simple that I couldnt think of...
>>> Humbly yours,
>>> Raivo
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> http://iap.md, The future is open
