[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
Milo van der Linden
mlinden at zeelandnet.nl
Thu Oct 22 11:03:18 EDT 2009
I had my IIS crash so severe after a windows update once that it forced
me to switch to ms4w...
Mostly, it has to do with rights/authentication. Are you sure your IIS
user is allowed to connect to your database?
Daniel Walton schreef:
> Paul,
> I got various errors with MapServer running in IIS 7.5 until I
> installed the latest build of PHP. Don't know if you've done that
> already, but I thought I would mention it.
> Regards,
> Dan Walton
> gisfiretools.com <http://gisfiretools.com>
> On Thu, Oct 22, 2009 at 9:29 AM, Paul james <pauljame at gmail.com
> <mailto:pauljame at gmail.com>> wrote:
> Hi Tamas!
> Thanks...
> Yes, thats working on Windows 2003/XP...
> The problem is happening only on Windows 7 (IIS 7.5) now...
> HTTP Error 502.2 - Bad Gateway
> Do you have any idea what is that? Its work fine with postgis...
> Paul
> On Wed, Oct 21, 2009 at 5:00 PM, Tamas Szekeres
> <szekerest at gmail.com <mailto:szekerest at gmail.com>> wrote:
> Paul,
> I've set up your data but it works for me:
> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=mssql2008.map
> <http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=mssql2008.map>
> tried with the following binaries:
> http://vbkto.dyndns.org/sdk/release-1500-gdal-1-6-mapserver-5-4.zip
> http://vbkto.dyndns.org/sdk/release-1500-gdal-mapserver.zip
> My mapfile:
> MAP
> NAME "SQL2008"
> STATUS ON
> SIZE 500 500
> IMAGETYPE PNG
> IMAGECOLOR 254 254 254
> EXTENT -79.7892 -44.2426 -24.9958 -9.11775
> LAYER
> NAME "tblGeo_AmericaSul"
> TYPE POLYGON
> CONNECTIONTYPE PLUGIN
> PLUGIN "msplugin_mssql2008.dll"
> CONNECTION
> "server=.\MSSQLSERVER2008;database=Maps;Integrated Security=true"
> DATA "the_geom from tblGeo_AmericaSul USING
> UNIQUE CodigoAmericaSul USING SRID=0"
> STATUS DEFAULT
> CLASS
> STYLE
> COLOR 255 0 0
> END
> END
> END
> END
> Best regards,
> Tamas
> 2009/10/21 Paul james <pauljame at gmail.com
> Tamas, the actual error generated is:
> The specified CGI application misbehaved by not returning
> a complete set of HTTP headers. The headers it did return
> are "".
> Using Windos 7 (IIS 7)
> Testing on Windows 2003, I got just a Blank image (no
> error message)...
> You can use the same mssql2008 data I sended you last time...
> Paul
> On Tue, Oct 20, 2009 at 4:56 PM, Tamas Szekeres
> Paul,
> I couldn't reproduce your problem by using my data and
> the recent mapserv version.
> http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=sql2008.map
> <http://vbkto.dyndns.org/cgi-bin/mapserv.exe?mode=map&map=sql2008.map>
> Could you provide your data for testing?
> Best regards,
> Tamas
> 2009/10/20 Paul james <pauljame at gmail.com
> Hello Tamas
> Did you test that?
> Paul
> On Mon, Oct 19, 2009 at 3:40 PM, Paul james
> <pauljame at gmail.com <mailto:pauljame at gmail.com>>
> wrote:
> Testing :
> http://localhost/cgi-bin-54/mapserv.exe?map=C:/Mapserver/Mapfile/map.map&mode=map
> <http://localhost/cgi-bin-54/mapserv.exe?map=C:/Mapserver/Mapfile/map.map&mode=map>
> Using Postgis connection works fine with same
> setup...
> Using that mapfile with MAPSCRIPT/C# works
> fine as well...
> The problem is CGI + MSSQL2008 Plugin
> Mapfile:
> MAP
> EXTENT -79.7892 -34.2426 -24.9958 6.11775
> FONTSET "..\Fontes\Fontes.txt"
> IMAGECOLOR 230 254 254
> IMAGETYPE png
> SIZE 400 200
> STATUS ON
> UNITS dd
> NAME "Geral"
> OUTPUTFORMAT
> NAME "png"
> MIMETYPE "image/png"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE "PC256"
> TRANSPARENT TRUE
> END
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> WEB
> IMAGEPATH 'C:\map\temp'
> IMAGEURL '/tmp/'
> QUERYFORMAT text/html
> LEGENDFORMAT text/html
> BROWSEFORMAT text/html
> END
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> KEYSPACING 10 5
> IMAGECOLOR 255 255 255
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> TEMPLATE "..\template.html"
> END
> QUERYMAP
> COLOR 255 0 0
> SIZE -1 -1
> STATUS ON
> STYLE hilite
> END
> REFERENCE
> IMAGE "..\reference.png"
> STATUS on
> SIZE 221 150
> MINBOXSIZE 5
> MAXBOXSIZE 150
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> MARKERSIZE 8
> END
> LAYER
> NAME test
> GROUP "tests"
> TYPE POLYGON
> STATUS ON
> CONNECTION "server=x;Integrated
> Security=false;database=x;uid=x;pwd=x"
> DATA "the_geom from viwgeo_paisbrasil USING
> UNIQUE oid USING SRID=0"
> CLASS
> COLOR 255 200 255
> END
> END
> END
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
