[mapserver-users] Re: Print template and WMS
Ruby
minerdiggins at gmail.com
Thu Oct 22 11:56:31 EDT 2009
Thanks for your thoughts Dan,
I reduced the output size of print.html to the same size as my map.html and
still no joy.
mapserver never calls the WMS layer for print.html although it loads fine in
my map.html.
bean
On Thu, Oct 22, 2009 at 6:33 AM, Dan Little <danlittle at yahoo.com> wrote:
> The WMS service you are calling may have a limit on the size of images it
> will return.
> ----- Original Message ----
> > From: Steve Lime <Steve.Lime at dnr.state.mn.us>
> > To: Ruby <minerdiggins at GMAIL.COM>; mapserver-users at lists.osgeo.org
> > Sent: Wed, October 21, 2009 4:37:05 PM
> > Subject: Re: [mapserver-users] Print template and WMS
> > And the WMS layer's name in question appears in the [layers] output?
> > >>> On 10/7/2009 at 2:20 PM, in message
> > <731ed3bb0910071220x4943b5beqc22f4516b86eed79 at mail.gmail.com>, Ruby
> > wrote:
> > > Greetings,
> > > I employ a print function via javascript button in an HTML map
> template. The
> > > print template produces a higher resolution version of the existing map
> in a
> > > new window. The print form I am using works perfectly except for my
> single
> > > WMS client layer, all other layers display except this one. The WMS
> layer
> > > displays correctly in my main map window. The tmp file image does not
> > > include the WMS data.
> > > Can anyone please guide me in including the WMS data in my print
> template? I
> > > would rather not call the WMS server again for my print template as
> > > connections to this server are very slow. All other data is stored
> locally.
> > > Below are my javascript call button and the HTML print template.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091022/2d2c2514/attachment.html
