[mapserver-users] Re: Print template and WMS
Ruby
minerdiggins at gmail.com
Thu Oct 22 14:50:00 EDT 2009
This would be easier to debug if we could see the app in action...
Thanks for your reply Steve,
I am unsure how I could share the app. I cannot host from my ISP and the
data approaches 5 GB.
I am using mapserver 5.2 on MacOsx 10.4.1 and ms4w 5.2 on WindowsXP ProSP3.
The app is plain vanilla- no python, mapscript, java, or third party
interfaces. Just straight html without frames, even the legend is html on
the map page. The few lines of javascript I use are not app related, just
invoking windows, sizing, calling a local app for gps download and the
button to this one url for print.html. All files are local to the server
except this client WMS layer.
I develop on the Mac and port to the Windows machine, The Windows machine is
not connected to the WAN. I test on both machines. I set up a dummy dns on
the LAN and ms4w on the Windows machine does try to connect when invoked
from the main window but makes not attempt a connection for print.html, the
same behavior observed on the Mac version with a real WAN connection.
The WMS layer loads fine in several different map templates I've built. It
is only when the URL
http:/localhost:8888/cgi-bin/mapserv?map=[map]&mapext=[mapext]&layers=[layers]&map_web=TEMPLATE+pgs/print.html&mapsize=1500+1182
is called that mapserver does not attempt to connect the WMS layer. I
suspect something is missing in the above URL.
Thank you again,
bean
On Thu, Oct 22, 2009 at 9:05 AM, Steve Lime <Steve.Lime at dnr.state.mn.us>
>>> On 10/22/2009 at 10:56 AM, in message
<731ed3bb0910220856j3704b29bm61139ee355c59c3f at mail.gmail.com>, Ruby
<minerdiggins at gmail.com> wrote:
> Thanks for your thoughts Dan,
> I reduced the output size of print.html to the same size as my map.html
and
> still no joy.
> mapserver never calls the WMS layer for print.html although it loads fine
in
> my map.html.
> bean
> On Thu, Oct 22, 2009 at 6:33 AM, Dan Little <danlittle at yahoo.com> wrote:
>> The WMS service you are calling may have a limit on the size of images it
>> will return.
>> ----- Original Message ----
>> > From: Steve Lime <Steve.Lime at dnr.state.mn.us>
>> > To: Ruby <minerdiggins at GMAIL.COM>; mapserver-users at lists.osgeo.org
>> > Sent: Wed, October 21, 2009 4:37:05 PM
>> > Subject: Re: [mapserver-users] Print template and WMS
>> > And the WMS layer's name in question appears in the [layers] output?
>> > >>> On 10/7/2009 at 2:20 PM, in message
>> > <731ed3bb0910071220x4943b5beqc22f4516b86eed79 at mail.gmail.com>, Ruby
>> > wrote:
>> > > Greetings,
>> > > I employ a print function via javascript button in an HTML map
>> template. The
>> > > print template produces a higher resolution version of the existing
map
>> in a
>> > > new window. The print form I am using works perfectly except for my
>> single
>> > > WMS client layer, all other layers display except this one. The WMS
>> layer
>> > > displays correctly in my main map window. The tmp file image does not
>> > > include the WMS data.
>> > > Can anyone please guide me in including the WMS data in my print
>> template? I
>> > > would rather not call the WMS server again for my print template as
>> > > connections to this server are very slow. All other data is stored
>> locally.
>> > > Below are my javascript call button and the HTML print template.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091022/9f9ff28d/attachment.html
