[mapserver-users] PHP Mapscript delivers map with larger extent
than requested
Chuck Jungmann
chuck at cpjj.net
Sat Oct 24 22:44:18 EDT 2009
I am a new user of MapServer, using version 5.0.3 from the Ubuntu
repositories. I attempted to compile everything from source, had some
trouble, then decided to use the repository shortcut at least until I
understood how the application works.
I am writing an application where the browser requests a map by setting
the src attribute of an img object. Identifying locations on the
resulting map requires that the application knows the extent.
I calculate the extent of the map from various values, and use the same
algorithms on the server so the browser and the server agree on the
dimensions without having to negotiate. However, when I request the map
from MapServer, the extent of the resulting map is always larger (both x
and y dimensions) than what I requested, although still centered on the
same point.
Is this behavior normal (I don't want to beat my head against the wall
searching for an irrelevant math error)? Is there some setting that
might cause MapServer to more closely match my requested extent? Could
this be an error that was fixed in a more recent version of MapServer?
Any words of wisdom would be appreciated.
Chuck Jungmann
