[mapserver-users] OSM data rendering using Mapserver
Ali_
ali_informatics at yahoo.com
Thu Oct 29 09:03:55 EDT 2009
Thanks Rahkonen,
I'll see what's wrong with this makefile then. It's still giving me command
syntax error in line 7, 9 and 12 of makefile downloaded from
http://code.google.com/p/mapserver-utils/source/browse/trunk/
Ali.
Rahkonen Jukka wrote:
> Hi
> Ali_ wrote:
>> 2) The osm_line and osm_road table have not been assigned the
>> primary key while conversion using osm2pgsql and where we
>> query in the map file we use USING UNIQUE osm_id which may be
>> incompatible and may be make is unable to give the result.
> At least the osm2pgsql version I am using is creating dublicate osm_ids
> on these layers because relations which are converted to lines are
> getting the osm_id of a relation and there can also be same osm_id used
> by an OSM line feature. Mapfile works still even it if USING UNIQUE
> refers to a non unique field.
> -Jukka Rahkonen-
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/OSM-data-rendering-using-Mapserver-tp3911799p3912145.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
