[mapserver-users] Use of palette file: Problems with
changingcolors when tiling
Espen Isaksen
espen.isaksen at gmail.com
Thu Oct 29 09:17:03 EDT 2009
No, that color is not present in the mapfile or in the palette.txt
file. We use the color 108 189 243 on lakes.
This is happening on other features(with other colors) for us as well.
I did test to fill up the palette file with the same colors more than
one time in order to get 256 colers in the file and that actually
fixed the problem. However, it created all other kind of problems with
the colors, especially with anti-aliasing on labels.
Espen
2009/10/28 Steve Lime <Steve.Lime at dnr.state.mn.us>:
> Is the color 125,202,228 (the water value in the image on the left) used in your mapfile?
>>>> On 10/28/2009 at 5:25 AM, in message
> <a4cd3760910280325l4c4a1feah93782aeb259462d2 at mail.gmail.com>, Espen Isaksen
> <espen.isaksen at gmail.com> wrote:
>> Hi!
>> We are testing out using a palette file in our outputformat to
>> decrease file size in the png output. Most of the time this works
>> great, but some times when we are tiling the data we get some errors.
>> The color seem to shift to a similar color from one tile to another.
>> We have added the colors we use in the map file in the palette.txt
>> file. The documentation says it needs 256 colors in the map file, but
>> we do not use that many colors right now. (we tried adding the same
>> color more than one time, but that created other problems....)
>> I have attached a png file showing the problem across a lake. The
>> color on the right side is the correct color and the color we have
>> added to the palette file. The color on the left side of the lake is
>> not something we have set.
>> I have also added the palette.txt file and the outputformat we use is this:
>> OUTPUTFORMAT
>> NAME "png"
>> DRIVER "AGG/PNG"
>> MIMETYPE "image/png"
>> IMAGEMODE "rgb"
>> EXTENSION "png"
>> FORMATOPTION "PALETTE_FORCE=TRUE"
>> FORMATOPTION "PALETTE=/data/maps/palette.txt"
>> END
>> Does anybody know why this happens in Mapserver and how to fix it?
>> Espen
