[mapserver-users] OSM data rendering using Mapserver
Ali_ ali_informatics at yahoo.com
Sat Oct 31 10:27:35 PDT 2009
Thanks David for your response. Yeah I was using old version. The problem is
sorted out.
Fawcett, David wrote:
> Probably.  MAXSCALEDENOM was introduced around version 5.0.  Are you
> using an old version of MapServer?
> What version are you using?  What does your map file look like?
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ali_
> Sent: Thursday, October 29, 2009 5:34 PM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] OSM data rendering using Mapserver
> Hi Stephen,
> Thanks for your response. I am grateful to you. Cygwin worked.
> I am getting this error
> loadLabel(): Unknown identifier. Parsing error near
> (MAXSCALEDENOM):(line
> 48)
> Is that something to do with the Mapserver versions?
> Ali.
> Stephen Woodbridge wrote:
>> Ali_ wrote:
>>> Hi,
>>> I am new to MapServer and wanted to render OSM data through that. I
>>> followed
>>> the tutorial
>>> http://trac.osgeo.org/mapserver/wiki/RenderingOsmData
>>> but unfortunately I am unable to run it at the final stage. I am on
> the
>>> last
>>> step where I use 'make' command to compile osm.map file as an output
> but
>>> something seems wrong. I am getting 3 syntax errors in makefile. Now
> I am
>>> using Borland C++ compiler make utility. Before that I tried with TC
>>> compiler make utility. I was getting 5 syntax errors before but now
> its
>>> only
>>> 3. So I have some points in my mind which if you could clarify.
>> cpp is the GNU C preprocessor, you might have better luck if you
> install
>> cygwin on Windows.
>>> 1) The other map files such as landuse, buildings and highways have
> not
>>> MAP
>>> keyword at the start of each file. Though I tried with this but still
>>> couldn't get it working.
>> The map file is broken into logical pieces and uses lots of variables
>> that get resolved and replaces by the cpp. You can not use them as
> they
>> are. When cpp runs all the pieces get assembled into the usable
> mapfile.
>>> 2) The osm_line and osm_road table have not been assigned the primary
> key
>>> while conversion using osm2pgsql and where we query in the map file
> we
>>> use
>>> USING UNIQUE osm_id which may be incompatible and may be make is
> unable
>>> to
>>> give the result.
>> This probably will not impact mapserver running unless you are
> guerying
>> the features.
>>> 3) The first line in the makefile CPP=cpp tells about the compiler we
> are
>>> using. Could you tell me which exactly is the compiler I should use.
>> This is the GNU C preprocessor.
>>> I shall be grateful if I could get some comments from you. Thanking
> you
>>> in
>>> anticipation.
>>> Cheers,
>>> Ali
>> Hope this helps,
>>    -Steve W
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> http://n2.nabble.com/OSM-data-rendering-using-Mapserver-tp3911799p391596
> 5.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/OSM-data-rendering-using-Mapserver-tp3911799p3924554.html
More information about the MapServer-users mailing list
