[mapserver-users] Help with NQuery error (CGI)
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Thu Oct 29 10:06:42 EDT 2009
I'm no expert on this one, but . . .
If you do an NQUERY Mapserver needs to know which layer you plan on
querying, either by name, explicitly through the call (layer=??) or by
having the mapfile give them up by default (STATUS=default ??), either
way, mapserver need to know somehow what to apply the query to, I think.
Also, how do you want mapserver to output the results of the NQUERY? by
templated output or . . . you can use NQUERYMAP I believe to get an
image back of the NQUERY . . .
bobb
>>> Paul james <pauljame at gmail.com> wrote:
Hello guys...
I´m got this error when trying to execute a Nquery :
http://localhost/cgi-bin-54/mapserv.exe?map=Map.map&mode=nquery&LAYERS=TEST&mapext=-58.358076171875+-11.42570625+-57.193525390625+-10.37101875&imgext=-58.358076171875+-11.42570625+-57.193525390625+-10.37101875&map_size=1221+762&imgxy=1221+762&imgbox=0+0+1221+762
msDrawMap(): Image handling error. Failed to draw layer named 'TEST'.
But, If I execute the same url with "mode=map", the image is generated
fine... What this error means?
TEST Layer
LAYER
NAME TEST
GROUP "TE"
TYPE polygon
STATUS ON
CONNECTIONTYPE PLUGIN
PLUGIN "msplugin_mssql2008.dll"
CONNECTION "server=X;Integrated Security=false;database=X;uid=X;pwd=X"
DATA "the_geom from viw USING UNIQUE oid USING SRID=0"
CLASS
TEMPLATE "template.html"
NAME "X"
STYLE
OUTLINECOLOR 150 150 150
WIDTH 1
END
END
END
Thanks
Paul
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091029/113e737f/attachment.html
