[mapserver-users] Use of palette file: Problems with
changingcolors when tiling
Espen Isaksen
espen.isaksen at gmail.com
Thu Oct 29 09:37:11 EDT 2009
Yes, we know, but we just tried to bypass the problem by fooling
Mapserver. And that did not work :-) That was just a test, which might
show that Mapserver is filling in some Mapserver defined color in the
waterlayer when it shouldn't.
Espen
2009/10/29 Stephen Woodbridge <woodbri at swoodbridge.com>:
> The correct usage of the palette file is to NOT fill it up with 256 colors.
> What you want to do it get all the colors that you explicitly reference in
> the mapfile and place them in the palette file. then mapserver will initiate
> you file with these colors. Then when you antialias something mapserver will
> use the remain color slots and fill them with the antialiased generated
> colors.
> -Steve W
> Espen Isaksen wrote:
>> No, that color is not present in the mapfile or in the palette.txt
>> file. We use the color 108 189 243 on lakes.
>> This is happening on other features(with other colors) for us as well.
>> I did test to fill up the palette file with the same colors more than
>> one time in order to get 256 colers in the file and that actually
>> fixed the problem. However, it created all other kind of problems with
>> the colors, especially with anti-aliasing on labels.
>> Espen
>> 2009/10/28 Steve Lime <Steve.Lime at dnr.state.mn.us>:
>>> Is the color 125,202,228 (the water value in the image on the left) used
>>> in your mapfile?
>>>>>> On 10/28/2009 at 5:25 AM, in message
>>> <a4cd3760910280325l4c4a1feah93782aeb259462d2 at mail.gmail.com>, Espen
>>> Isaksen
>>> <espen.isaksen at gmail.com> wrote:
>>>> Hi!
>>>> We are testing out using a palette file in our outputformat to
>>>> decrease file size in the png output. Most of the time this works
>>>> great, but some times when we are tiling the data we get some errors.
>>>> The color seem to shift to a similar color from one tile to another.
>>>> We have added the colors we use in the map file in the palette.txt
>>>> file. The documentation says it needs 256 colors in the map file, but
>>>> we do not use that many colors right now. (we tried adding the same
>>>> color more than one time, but that created other problems....)
>>>> I have attached a png file showing the problem across a lake. The
>>>> color on the right side is the correct color and the color we have
>>>> added to the palette file. The color on the left side of the lake is
>>>> not something we have set.
>>>> I have also added the palette.txt file and the outputformat we use is
>>>> this:
>>>> OUTPUTFORMAT
>>>> NAME "png"
>>>> DRIVER "AGG/PNG"
>>>> MIMETYPE "image/png"
>>>> IMAGEMODE "rgb"
>>>> EXTENSION "png"
>>>> FORMATOPTION "PALETTE_FORCE=TRUE"
>>>> FORMATOPTION "PALETTE=/data/maps/palette.txt"
>>>> END
>>>> Does anybody know why this happens in Mapserver and how to fix it?
>>>> Espen
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
