[mapserver-users] OSM data rendering using Mapserver
Fawcett, David
David.Fawcett at state.mn.us
Fri Oct 30 09:20:31 EDT 2009
Probably. MAXSCALEDENOM was introduced around version 5.0. Are you
using an old version of MapServer?
What version are you using? What does your map file look like?
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ali_
Sent: Thursday, October 29, 2009 5:34 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] OSM data rendering using Mapserver
Hi Stephen,
Thanks for your response. I am grateful to you. Cygwin worked.
I am getting this error
loadLabel(): Unknown identifier. Parsing error near
(MAXSCALEDENOM):(line
48)
Is that something to do with the Mapserver versions?
Ali.
Stephen Woodbridge wrote:
> Ali_ wrote:
>> Hi,
>> I am new to MapServer and wanted to render OSM data through that. I
>> followed
>> the tutorial
>> http://trac.osgeo.org/mapserver/wiki/RenderingOsmData
>> but unfortunately I am unable to run it at the final stage. I am on
the
>> last
>> step where I use 'make' command to compile osm.map file as an output
but
>> something seems wrong. I am getting 3 syntax errors in makefile. Now
I am
>> using Borland C++ compiler make utility. Before that I tried with TC
>> compiler make utility. I was getting 5 syntax errors before but now
its
>> only
>> 3. So I have some points in my mind which if you could clarify.
> cpp is the GNU C preprocessor, you might have better luck if you
install
> cygwin on Windows.
>> 1) The other map files such as landuse, buildings and highways have
not
>> MAP
>> keyword at the start of each file. Though I tried with this but still
>> couldn't get it working.
> The map file is broken into logical pieces and uses lots of variables
> that get resolved and replaces by the cpp. You can not use them as
they
> are. When cpp runs all the pieces get assembled into the usable
mapfile.
>> 2) The osm_line and osm_road table have not been assigned the primary
key
>> while conversion using osm2pgsql and where we query in the map file
we
>> use
>> USING UNIQUE osm_id which may be incompatible and may be make is
unable
>> to
>> give the result.
> This probably will not impact mapserver running unless you are
guerying
> the features.
>> 3) The first line in the makefile CPP=cpp tells about the compiler we
are
>> using. Could you tell me which exactly is the compiler I should use.
> This is the GNU C preprocessor.
>> I shall be grateful if I could get some comments from you. Thanking
you
>> in
>> anticipation.
>> Cheers,
>> Ali
> Hope this helps,
> -Steve W
View this message in context:
http://n2.nabble.com/OSM-data-rendering-using-Mapserver-tp3911799p391596
5.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
