[mapserver-users] Help with NQuery error (CGI)
Paul james
pauljame at gmail.com
Fri Oct 30 13:22:38 EDT 2009
I think so...
Is it related with that ticket?
http://trac.osgeo.org/mapserver/ticket/3058
Paul
On Fri, Oct 30, 2009 at 1:53 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>wrote:
> Odd. Unfortunately I can't debug anything related to MSSQL2008, perhaps
> the driver isn't
> supporting functions necessary to complete a query?
> Steve
> >>> On 10/30/2009 at 6:33 AM, in message
> <33fad6880910300433i342c619am99935a607896643f at mail.gmail.com>, Paul
> james
> <pauljame at gmail.com> wrote:
> > Hey Steve...
> > Yes I had...
> > QUERYMAP
> > COLOR 255 0 0
> > SIZE -1 -1
> > STATUS ON
> > STYLE hilite
> > END
> > With Status OFF I got that :
> > Content-type: text/html
> > Using MSSQL2008
> > Paul
> > On Thu, Oct 29, 2009 at 6:13 PM, Steve Lime
> >> Do you have a querymap object configured with status on? I would
> guess
> >> so in order to see that
> >> error. What happens if you set STATUS OFF in the querymap?
> >> >>> On 10/29/2009 at 7:57 AM, in message
> >> <33fad6880910290557m71ee3fdatd470590e3256f175 at mail.gmail.com>, Paul
> >> james
> >> > Hello guys...
> >> > Ím got this error when trying to execute a Nquery :
> http://localhost/cgi-bin-54/mapserv.exe?map=Map.map&mode=nquery&LAYERS=TEST&mape
> > x
> t=-58.358076171875+-11.42570625+-57.193525390625+-10.37101875&imgext=-58.35807
> > 61718
> 75+-11.42570625+-57.193525390625+-10.37101875&map_size=1221+762&imgxy=1221+762&i
> > mgb
> >> > ox=0+0+1221+762
> >> > msDrawMap(): Image handling error. Failed to draw layer named
> >> 'TEST'.
> >> > But, If I execute the same url with "mode=map", the image is
> >> generated
> >> > fine... What this error means?
> >> > TEST Layer
> >> > LAYER
> >> > NAME TEST
> >> > GROUP "TE"
> >> > TYPE polygon
> >> > STATUS ON
> >> > CONNECTIONTYPE PLUGIN
> >> > PLUGIN "msplugin_mssql2008.dll"
> >> > CONNECTION "server=X;Integrated
> >> Security=false;database=X;uid=X;pwd=X"
> >> > DATA "the_geom from viw USING UNIQUE oid USING SRID=0"
> >> > CLASS
> >> > TEMPLATE "template.html"
> >> > NAME "X"
> >> > STYLE
> >> > OUTLINECOLOR 150 150 150
> >> > WIDTH 1
> >> > END
> >> > END
> >> > END
> >> > Thanks
> >> > Paul
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091030/1d17f3ed/attachment.html
