[mapserver-users] local shapefile not rendering
Andy Colson
andy at squeakycode.net
Mon Aug 2 11:37:15 EDT 2010
On 8/2/2010 10:30 AM, geo3d wrote:
> Looking for some insight to further troubleshoot my problem;
> pulling my parcels shapefile locally does not render my shapefile:
> Mapfile
> DATA 'parcels'
> Projection
> init=epsg:2240
> END
> However, pulling the data directly from postgresql does render; with the
> same projection used
> NAME 'Parcels'
> TYPE POLYGON
> CONNECTIONTYPE postgis
> CONNECTION "dbname='********' host=***** port=5432 user='***'
> password='***' sslmode=prefer"
> DATA 'the_geom FROM "parcels" using unique gid using srid=2240'
> Can anyone suggest any ideas?
> Thanks
Your example is a little small, so its hard to tell. My first guess is
SHAPEPATH is not set.
The mapfile should be like:
MAP
SHAPEPATH '/data/maps/...'
LAYER
NAME 'Parcels'
TYPE POLYGON
-Andy
