[mapserver-users] local shapefile not rendering
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Aug 2 11:38:47 EDT 2010
geo3d wrote:
> Looking for some insight to further troubleshoot my problem;
> pulling my parcels shapefile locally does not render my shapefile:
> Mapfile
> DATA 'parcels'
> Projection
> init=epsg:2240
> END
> However, pulling the data directly from postgresql does render; with the
> same projection used
> NAME 'Parcels'
> TYPE POLYGON
> CONNECTIONTYPE postgis
> CONNECTION "dbname='********' host=***** port=5432 user='***'
> password='***' sslmode=prefer"
> DATA 'the_geom FROM "parcels" using unique gid using srid=2240'
> Can anyone suggest any ideas?
> Thanks
Hello,
If I were you I would test your shapefile-mapfile with the shp2img
utility, and enable debugging
(http://www.mapserver.org/optimization/debugging.html) and then paste
your exact error into your next email to the emailing list.
I would also remove all other layers, and all projection objects, and
set the EXTENT parameter to the extents of your shapefile, and then
retry shp2img.
Hope that helps you get moving in the right direction.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
