[mapserver-users] Problems with Query Template (Chameleon)
Andy Hird
andy.hird at aligned-assets.co.uk
Fri Apr 8 04:00:16 EDT 2011
Hi there - really need some help if you can please regarding Template
Query feature, and I have googled to exhaustion :-/
Background:
I have an existing Map file referencing MapInfo Tab files running under
ms4w_2.3.1 & chameleon_ms4w-2.4.1
I have installed ms4w - V3.0.1 and chameleon V2.6.0
Copied my Map file across and made the necessary adjustments to get it
working.
However when using the Query Widget (info of layers at mouse click)
against MapInfo Layers it is no longer returning results, and yet it did
previously.
My knowledge is not that great in php etc - but I suspect that its
requiring a dbf rather than MapInfo Tab as it does work with a shp, dbf
set of files.
Can Anyone help please as I really struggling - ideally I just want to
use the old widget.
However If someone can provide example of placing a button on a html
page that would call query functionality that would be very helpful too.
Thanks in advance
Andy
The information contained in or attached to this message is the responsibility of the sender and is meant for the confidential use of the intended recipients. It does not necessarily represent the position of Aligned Assets. If you are not an intended recipient you are notified that you have received this communication in error and that review, dissemination or copying of this communication is prohibited.
If you have received this in error, please notify us.
Aligned Assets Limited
Unit 5
River Court
Albert Drive
Sheerwater
Woking
GU21 5RP
Company Registration No: 4610724
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110408/933613a5/attachment.html
