[mapserver-users] error in raster layer
morteza shabihkhani
m.shabihkhani at gmail.com
Fri Apr 8 08:20:57 PDT 2011
Thank you,
Because I'm new in Mapserver, I don't know how to track the errors. Could
you please help me to check the permissions.
On Fri, Apr 8, 2011 at 2:45 AM, fruitwerks <fruitwerks at gmail.com> wrote:
> That error is fairly vague. The first thing I would look at is
> permissions. Also a good rule of thumb is to not use () in file or
> directory names.
> On Thu, Apr 7, 2011 at 9:16 PM, morteza shabihkhani
> <m.shabihkhani at gmail.com> wrote:
> > Hello all,
> > I want to create a very simple raster layer, but I faced to this error:
> > msDrawMap(): Image handling error. Failed to draw layer named
> 'elevation'.
> > msDrawRaster(): Unable to access file. stcon using full path stcon
> > this is my layer:
> > LAYER
> > NAME elevation
> > TYPE raster
> > STATUS on
> > DATA stcon
> > PROJECTION
> > "init=epsg:2260"
> > END
> > CLASS
> > STYLE
> > OUTLINECOLOR 0 200 0
> > END
> > END
> > END
> > I checked paths and names, and everything is correct.
> > I should note that I try to look at the only raster layer of itasca, but
> > although all other layers are working very well, running this layer
> causes
> > this error:
> > msDrawMap(): Image handling error. Failed to draw layer named 'drgs'.
> > msDrawRaster(): Image handling error. Unrecognized or unsupported image
> > format drawEPP(): Image handling error.
> > /var/www/Mapserver/Amin(Itasca)/data/drgncimq1926.tif is not an EPPL
> file.
> > Thank you in advance for your help.
> > Amin
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> _______________________________________________________________________________
> Any use, dissemination, distribution, posting on Internet bulletin
> boards, disclosure or copying of this e-mail or any information
> contained herein by or to anyone other than the intended recipient(s)
> is strictly prohibited. Use of this content for any other purpose is a
> violation of International Copyright Laws.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110408/94961e6b/attachment.htm>
More information about the MapServer-users
