[mapserver-users] Transparency of overlapping PNG-symbols
thomas bonfort
thomas.bonfort at gmail.com
Fri Apr 8 10:52:53 EDT 2011
Given the artifact, I'd say that you are using the GD renderer. Are
you sure it's the AGG one that is being selected when you create that
image?
thomas
2011/4/8 Lime, Steve D (DNR) <steve.lime at state.mn.us>:
> Can you share the batnight.png file? Any difference if you remove "TRANSPARENT 0"? It shouldn't have any
> effect since transparency is picked up from the pixmap. By chance does this work ok in 6.0?
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephan Holl
> Sent: Friday, April 08, 2011 8:43 AM
> To: mapserver-users at lists.osgeo.org
> Cc: Björn Schilberg
> Subject: [mapserver-users] Transparency of overlapping PNG-symbols
> Dear list,
> while developing an application with PNG-symbols rendered on top of a map I have encountered a problem if the PNG-symbols overlap each other; artefacts are present (see attachment).
> The Symbols are defined as following:
> SYMBOL
> NAME "Batnight"
> TYPE PIXMAP
> IMAGE "./images/batnight.png"
> TRANSPARENT 0
> END
> Used outputformat:
> OUTPUTFORMAT
> NAME agg
> DRIVER AGG/PNG
> IMAGEMODE RGB
> END
> Is there an easy way to let them disappear or is this a (perhaps known) bug in MapServer?
> I am using the AGG-renderer and MS 5.6.6 though.
> TIA
> Stephan
> Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663 Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
> Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
