[mapserver-users] Transparency of overlapping PNG-symbols
Lime, Steve D (DNR)
steve.lime at state.mn.us
Fri Apr 8 10:31:27 EDT 2011
Can you share the batnight.png file? Any difference if you remove "TRANSPARENT 0"? It shouldn't have any
effect since transparency is picked up from the pixmap. By chance does this work ok in 6.0?
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephan Holl
Sent: Friday, April 08, 2011 8:43 AM
To: mapserver-users at lists.osgeo.org
Cc: Björn Schilberg
Subject: [mapserver-users] Transparency of overlapping PNG-symbols
Dear list,
while developing an application with PNG-symbols rendered on top of a map I have encountered a problem if the PNG-symbols overlap each other; artefacts are present (see attachment).
The Symbols are defined as following:
SYMBOL
NAME "Batnight"
TYPE PIXMAP
IMAGE "./images/batnight.png"
TRANSPARENT 0
END
Used outputformat:
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
END
Is there an easy way to let them disappear or is this a (perhaps known) bug in MapServer?
I am using the AGG-renderer and MS 5.6.6 though.
TIA
Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663 Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
