[mapserver-users] error in raster layer
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 8 10:42:36 EDT 2011
On 11-04-08 12:16 AM, morteza shabihkhani wrote:
> Hello all,
> I want to create a very simple raster layer, but I faced to this error:
> msDrawMap(): Image handling error. Failed to draw layer named 'elevation'.
> msDrawRaster(): Unable to access file. stcon using full path stcon
> this is my layer:
> LAYER
> NAME elevation
> TYPE raster
> STATUS on
> DATA stcon
Morteza,
I don't think you mentioned what binaries you are using. Could you confirm
that the "mapserv -v" output includes "INPUT=GDAL"? The error - particularly
the EPPL one, could mean you don't even have GDAL raster support built in.
In the above case, are you really really really sure the path is right?
You haven't provided any path so it ought to be evaluated relative to the
mapfile but to be very sure I'd suggest supplying a full path. Also, does
your file really have no extension? MapServer isn't going to guess an
extension!
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
