[mapserver-users] Transparency of overlapping PNG-symbols [solved]
Stephan Holl
stephan.holl at intevation.de
Mon Apr 11 04:03:04 EDT 2011
Hello thomas,
thomas bonfort <thomas.bonfort at gmail.com>, [20110411 - 09:41:54]
> Ok, thanks.
> could you check the same mapfile with GD on mapserver 6.0 to see if
> the issue still exists?
We will do so when we have set up a MS6-Box, which will be the case
soon since my collegue björn is going to package MS6 shortly in the
future.
Best
Stephan
> thomas
> On Mon, Apr 11, 2011 at 09:39, Stephan Holl
> <stephan.holl at intevation.de> wrote:
> > Hello thomas,
> > thomas bonfort <thomas.bonfort at gmail.com>, [20110408 - 16:52:53]
> >> Given the artifact, I'd say that you are using the GD renderer. Are
> >> you sure it's the AGG one that is being selected when you create
> >> that image?
> > At least I was, yes, but after looking at the _right_ mapfile it was
> > missing the AGG-rendering-options.
> > setting the following helps.
> > IMAGETYPE aggpng
> > #8bit png, supports transparency.
> > OUTPUTFORMAT
> > NAME aggpng
> > DRIVER AGG/PNG
> > MIMETYPE "image/png"
> > ## transparency only with RGBA Image Mode
> > ## mapserver had to be compiled -with-experimental-png
> > IMAGEMODE RGBA
> > EXTENSION "png"
> > FORMATOPTION "QUANTIZE_FORCE=ON"
> > FORMATOPTION "QUANTIZE_COLORS=256"
> > FORMATOPTION "QUANTIZE_NEW=ON"
> > TRANSPARENT ON
> > END
> > Best regards
> > Stephan
> >> 2011/4/8 Lime, Steve D (DNR) <steve.lime at state.mn.us>:
> >> > Can you share the batnight.png file? Any difference if you remove
> >> > "TRANSPARENT 0"? It shouldn't have any effect since transparency
> >> > is picked up from the pixmap. By chance does this work ok in 6.0?
> >> > Steve
> > Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508
> > 3663 Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück -
> > HR B 18998 Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr.
> > Jan-Oliver Wagner
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110411/a9bc495c/signature.bin
