[mapserver-users] msProcessProjection(): Projection library error.
no options in 'init' file
myOpenLayersUName
joanne.mcgraw at SYMPATICO.CA
Thu Apr 14 13:42:22 EDT 2011
We are trying to deploy a WMS to production that we have working in a
development environment. When I try to do a getCapabilities request in the
prod environment, I get the message provided in the subject above.
I looked at the documentation for this error message at
http://mapserver.org/errors.html. It tells me:
"The message tells you that the projection you’re trying to use isn’t
defined in the epsg file. Open your epsg file in a text editor and search
for your projection to make sure that it exists."
I have checked the epsg file in the prodution environment and the projection
I am asking for is included. Further, I have run a file comparison on the
epsg file in dev and the one in prod and they are the same.
Does anyone know of other reasons MapServer could be unable to find the
projection definition?
Cheers,
jtm
View this message in context: http://osgeo-org.1803224.n2.nabble.com/msProcessProjection-Projection-library-error-no-options-in-init-file-tp6273726p6273726.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
