[mapserver-users] how do min/max scale filters work?
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 6 10:37:14 EDT 2011
Does it draw if you remove both (MAX|MIN)SCALEDENOM?
If not the problem is probably not related to these.
-Steve W
On 4/6/2011 9:10 AM, PixelPusher wrote:
> I’ve got a simple thing in a MapServer page that doesn’t want to work. There is a layer in my map that I only want displayed if the scale of the view is between 1:24000 and 1:100000. However, I’ve had no luck using the MAXSCALEDENOM and MINSCALEDENOM keywords. As configured below, the layer never draws, regardless of the scale. The layer draws correctly if I comment out the scale tests. Can anyone show me the correct way to use this?
> The relevant section of the mapfile looks like this:
> LAYER
> NAME "BTSroads_local_PostGIS"
> TYPE LINE
> STATUS DEFAULT
> MAXSCALEDENOM 100000
> MINSCALEDENOM 24000
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=mapserver user=uuuu password=pppp port=5432"
> DATA "wkb_geometry from btsroads using unique ogc_fid using srid=4269"
> FILTER "fcc LIKE 'A4%'"
> CLASS
> NAME "Local Roads"
> STYLE
> COLOR 220 214 196
> END
> END
> END # layer
> Thanks,
> Thom
> Man will occasionally stumble over the truth, but most of the time
> he will pick himself up and continue. -- Winston Churchill
> mapserver-users at lists.osgeo.org
