[mapserver-users] Re: msProcessProjection(): Projection library
error. no options in 'init' file
myOpenLayersUName
joanne.mcgraw at SYMPATICO.CA
Thu Apr 14 14:20:43 EDT 2011
Thanks for your response Jeff. I'm guessing you responded before you received
my followup post regarding the location of the epsg file.
However, to address the concern, I did check and the MAP's projection is
defined with lowercase epsg and the "wms_srs" list is uppercase EPSG
following the example found at: http://mapserver.org/ogc/wms_server.html
discussing Map PROJECTION and wms_srs metadata.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/msProcessProjection-Projection-library-error-no-options-in-init-file-tp6273726p6273896.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
