[mapserver-users] Problems with png output when using libpng 1.5
thomas bonfort
thomas.bonfort at gmail.com
Wed Apr 20 10:28:52 EDT 2011
Christy,
I suspect this is due to a bug in libpng. see
http://sourceforge.net/tracker/index.php?func=detail&aid=3288207&group_id=5624&atid=105624
On Wed, Apr 20, 2011 at 15:20, Christy Nieman <cnieman at dmsolutions.ca> wrote:
> Hi,
> I compiled MapServer 6.0 beta6 against libpng 1.5.2 and encountered the
> following problems:
> when using the default png IMAGETYPE (i.e. no OUTPUTFORMAT block), I got
> yellow & striped maps (see cyprus.png)
> when using the AGG/PNG driver and IMAGEMODE "RGBA", the output image looks
> fine
> when using the default png8 IMAGETYPE, the output image looks fine
> I also compiled with cairo, and with the driver set to CAIRO/PNG, I had the
> same yellow & striped maps.
rgba and png8 use different png formats. agg/png and cairo/png use the
same codepath when saving images, so the behavior your are observing
is normal.
> With libpng 1.2.44, everything seems to work properly. Has anyone else seen
> this problem with libpng 1.5? Should it work properly with MapServer?
> Regards,
> Christy
> mapserver-users at lists.osgeo.org
